front 02 sensor wiring... there are two blacks are they both grd ?
Old Jun 19, 2006 | 11:46 PM
BoostWhore's Avatar
My 02 sensor was slightly damaged and i also had to get it off so i cut the wires. There are blue white and two blacks im assuming the two blacks are the same does anyone know forsure they should be grd and shouldnt matter if they were backwards thanks
Old Jun 20, 2006 | 08:14 AM
BoostWhore's Avatar
up
Old Jun 20, 2006 | 08:15 AM
bigric09's Avatar
im not sure but if you are cutting your 02 wires you are in bad shape to begin with... that gives your sensors some major issues
Old Jun 20, 2006 | 12:14 PM
althemean's Avatar
how? not if a proper splice is put in.
Old Jun 20, 2006 | 04:46 PM
bigric09's Avatar
a proper splice is almost always not sealed properly... not air tight
