EVO V engine, similar to EVO VII or VIII????
Here's the deal, a friend bought an EVO V RS last week, we want to order some parts, but were not sure if it's the same engine. I want to order camshafts and a set of lifters, but i'm not sure if they will fit.
Does any of you guys know somehing about this???
Thanks.
Cheers.
Thanks.
Cheers.
It wont work on EVO V, the Evo 4 to 6 have the same cams which are solid and from 7 and 8 have hollow cams the diameter is different. But i have cams for sale which will fit in Evo 4 to 6. The brand name is tomie and are 260s, .
The aftermarket cams for the 8 WILL fit the 5. Will slot straight in, but you will need to change the bolt going thru to the cam angle sensor. It doesnt matter that the stock cams are different between the models!!!
well finally, they will fit, unless for the cam sensor bolt, isn't it???
BTW, i cant find any web page to buy parts from tomei.
Thanks for the replys.
Brettpeters
Oct 10, 2013 03:21 PM
leonevox
106
May 4, 2010 01:28 PM
car, code, differences, efi, engine, evo, evolution, fit, lancer, mitsubishi, parts, philippines, sale, teksid, tme
