Turbo Inlet Pipe Removal...HELP!!!
Old Jun 29, 2006 | 07:27 PM
dakind916's Avatar
I'm trying to get the turbo inlet pipe off. But the screw is in an akward position. Basically underneath the inlet pipe. I'm having a heck of a time reaching it.
I've tried from the bottom and the top. I'd have more luck w/ it by removing the radiator fan, but it's hard to pull the fan out.
The reason I'm doing this is to install my mbc and I want to run it off the wastegate nipple and the turbo nipple.
Any suggestion on getting to that darn screw and loosening it?
Old Jun 29, 2006 | 07:41 PM
EvoRicer's Avatar
I used a long 10 mm socket...it reached the screw/bolt. If you don't have a long socket try using a shot socket and a small extension...
Old Jun 29, 2006 | 07:49 PM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
+1 to what he said. Or try taking off everything else that you can forward of that coupler and use a stubby to take it off. Make sure when you put it back on you keep it facing up so you can reach behind the coolant line to the turbo to get to it.
Old Jun 30, 2006 | 01:35 AM
EGHBauce's Avatar
If you end up taking off your radiator hose (middle top black one) make sure you have lots of paper towels to plug it or major spills.
Old Jun 30, 2006 | 01:38 AM
Warrtalon's Avatar
He's got it now. He didn't need to make this thread - he just forgot to IM Warrtalon. Everything is good now.
Old Jun 30, 2006 | 02:19 AM
Evo_Jay's Avatar
You should start a Mod consulting business
Old Jun 30, 2006 | 08:40 AM
Be honest now, do you TRY to make people hate you?
drb
53
Oct 25, 2016 08:50 AM
ElectricEvoIX
Jan 21, 2008 08:28 AM
Assassin
Dec 11, 2006 07:06 AM
Jersey Dino
11
Dec 10, 2006 09:54 AM
webguy330i
35
Aug 19, 2004 07:09 PM
Quick Reply: Turbo Inlet Pipe Removal...HELP!!!
