Help me figure out what noise I hear
There is a high pitched sound coming from under the rear of the car. its there all the time and does really change tone or volume with speed. its sounds like somebody using a vacume or haridryer very far away. its a high pitched faint sound and i noticed it when i was driving around without the rear seat cushions, maybe its a normal sound and is just amplified because there is no cushion? if i put my ear by each rear tire i can hear the noise. i crawl under the rear of the car i hear the noise. i can hear it faintly in the cabin. i put my ear by the front tires, i cant hear it as well. is this sound normal? what is it? if not, i will be making a trip to the dealership.
my car is completely stock, only ~6,000 miles on it and 05 model.
i did search and found some transfer case stuff, but i dont think that is what this is as the TC is at the front of the car.
thanks in advance
thanks in advance
first of all, you guys rock!
i searched through the tech forum and found how to access the fuel pump. i took off the cover and the sound is definitely coming from the fuel pump. is a slight whine normal? i took out my seat cushion so the sound isnt muffled anymore and i noticed the sound shortly after i removed the cushion. its a stock fuel pump.
