Restore Engine Restorer
I decided to put the Engine Restore to the test. With almost 50,000 mi. on my Evo, I decided to do a compression test and here is what I got.
Cylinder 1- 163 Psi
2- 155 Psi
3- 154 Psi
4- 154 Psi
I was not too happy about the results. I added this Engine Restore in with my oil change, drove 150 mi. and did another compression test and here is what I got.
1- 185 Psi
2- 185 Psi
3- 187 Psi
4- 185 Psi
Much better compression, honestly I was very impressed with this product and I think everyone with a higher mileage Evo should try it out.
Cylinder 1- 163 Psi
2- 155 Psi
3- 154 Psi
4- 154 Psi
1- 185 Psi
2- 185 Psi
3- 187 Psi
4- 185 Psi
This stuff has been out for years. I was using it in the late 80's and it does work.
I use it currently in my 93 B2600 that my dad gave me. I haven't checked my compression, but I do add it with every oil change.
Restore is definitely one of those products in a can that does do something.
Years ago I had this old honda that was a smoke machine! I used to put 8 cyl. restore in it (larger size) and it would stop smoking completely for about 3 days. Worked well enough to sell it.
Oh and it was the oil rings and no valve seals that were causing the smoking.
MRadjahoe (Apr 25, 2016)
