Can we get "Valet Maps"?
My friend with a Subaru STi has downloaded a "valet map" into his ECU which stalls the car if brough above 3,000 RPM. Is there anything like this avalable for the Evo?
Edit: i mean 4,000 rpm
Originally Posted by bigric09
3000 is kind of low i would think... 3500 or 4000 seems more likely.
Yea, I think you could easily set the rev limit to 4,000.
Set the 2-step to 1,000
Enter Boost solenoid duty cycle of 0, that way you can only run waste gate boost
That should be a pretty boring map...ahah
Originally Posted by XK120
lots of VW guys I know run this kinda map...they switch it through the cruise control switch
http://goapr.com/VW/products/ecu_upgrade_mkvgti.html
I may be wrong, but I don't think our ECUs give us a similar option without a piggyback unit.
