Water puddle?
Water puddle?
Got home from driving (with the a/c on...its hot here in CA) and after I shut the car off, I a puddle of water running from under the car.
I traced it to the driver's side coming from some plasic covering directly above the lwr front sway/tie/roll bar.
I checked my carpets to see if they were wet...and they weren't.
The car is still bone stock, and still runs fine.
Any ideas what this is?
Just check and make sure that your mufler bearings are still tight, if they arent you need to rebuild your tire houseing and assembly. PM me for more instructions, i did a write up on this earlier
