How much power loss is there with an exhaust silencer ?
Old Jul 26, 2006 | 05:52 AM
rcheung's Avatar
I have a megan turbo back exhaust. I was running the exhaust without the silencer for a while but decided yesterday to put it on. I was surprised with how quiet it is now. It feels a tad bit slower now. It could be just me not used to having a low noise exhaust. Does anyone know how much power loss there will be after the silencer installed?
Old Jul 26, 2006 | 06:17 AM
alloyic_rs's Avatar
it really robs your hp on high rpms
Old Jul 26, 2006 | 06:21 AM
justchil's Avatar
More than you think. You're better off getting a magnaflow muffler
Old Jul 26, 2006 | 06:45 AM
PVD04's Avatar
At your power level somewhere between 30 and 50 hp. This is based on a few dyno sheets I've seen.
-Paul
Old Jul 26, 2006 | 07:14 AM
rcheung's Avatar
-Paul
Wow thats a big chunk. Here I was thinking it was something like 10-15 hp.
Old Jul 26, 2006 | 07:28 AM
dudical26's Avatar
If I remeber correctly, I think Al dynoed a car that lost 50 hp with the silencer.
Old Jul 26, 2006 | 07:45 AM
Smike's Avatar
The loss is high. Just think about it in terms of flow. 3" v. 1.75" (+/-) (what the silencer restricts down to).
Personally, I only run my Apexi active tail silencer (spring loaded - opens under WOT), when I am on long trips (over 2 hrs away). I notice slower spool-up, and a weak top end.
Old Jul 26, 2006 | 08:04 AM
Warrtalon's Avatar
Yes, 30-40whp...may be even 50. We've seen dynosheets where a guy didn't know any better and had that thing in there, then when he took it out, he gained 40whp immediately. If people don't want loud, then don't get an exhaust. The silencer is worse than having the stock exhaust.
Old Jul 26, 2006 | 08:11 AM
PVD04's Avatar
That may be true, but the silencer isn't a bad option for people that want to be quiet for daily driving and then pull the silencer out when they get to the track. I don't use my silencer often, but I do put it in for long road trips (4+ hrs).
-Paul
Old Jul 26, 2006 | 08:56 AM
FJF's Avatar
FJF
This is the part that puzzles me. IME, your statement is correct, as every aftermarket Evo exhaust I've heard has been way too loud compared to stock - they range from loud to louder. OTOH, the aftermarket for German cars is able to offer quiet exhausts, as well as loud models, both offering similar gains (eg. Milltek, Techtonics). There's an opening in the Evo market for a quiet product. With more and more municipalities enforcing noise ordinances, quiet high-performance exhausts will be the way of the future. I'm surprised no one has taken advantage of this opportunity.
Old Jul 26, 2006 | 09:06 AM
KOEvo's Avatar
No 3 inch exhaust is going to be quiet, and that is what is required for turbo cars.
NA Econocars only require 2.5" MAX (barely larger then stock).
Old Jul 26, 2006 | 09:10 AM
Warrtalon's Avatar
Yeah, really, if it were possible to make a quiet 3" catless exhaust that makes 30whp, it would have been done already...
Old Jul 26, 2006 | 09:24 AM
FJF's Avatar
FJF
I've seen dyno results of 2.5", 2.75", and 3" exhausts on identical (turbo) cars and the outcome wasn't nearly as clear. I'm no expert, but there seems to be more at play than just the size of the piping. While the thrust of your comment may be correct (ie. the amplitude of a 3" exhaust), there's a distinct possibility that smaller diameter models may offer similar, if not better, performance relative to application, as well as a greatly reduced noise.
My point is this - if a firm were to offer a quiet Evo exhaust with dyno tests to illustrate the product's effectiveness, I bet they'd sell quite a few. Only a small number of manufacturers currently show comparative dyno results, and there may be a reason for it. Others seem to be selling of faith, which has little to do with a measurable standard we're up against.
Old Jul 27, 2006 | 05:53 AM
FJF's Avatar
FJF
Addendum:
Here's a 3" exhaust that's almost as quiet as stock. It's a shame it doesn't fit an Evo:
http://goapr.com/VW/products/apr_exhaust_mkvgti.html
Clearly, such a thing can be made.
bbak11010
Jan 3, 2011 09:30 PM
mr1444
Aug 8, 2008 02:01 PM
E\/0IXG$R
Oct 26, 2007 07:33 AM
TRDHarrier
15
Dec 15, 2003 08:46 AM
rljohnson
Sep 14, 2002 12:29 PM
