Mustang Dyno Sheet Baseline and w/ Tune Evo IX.
Old Aug 1, 2006, 08:41 AM
  #31
ROK EVO's Avatar
Originally Posted by ultraist
I had mods, buddy. TBE, MBC, Intake, Walbro, H34 BOV. My car wasn't stock. Also, as you can see. My wtq was lower then a stock cars, even with mods.
My bad, I didn't read carefully. Interesting info that you gained some whp without the ecu tune. Because I didn't gain any after installing TBE on my IX. I am guessing that it's your MBC. Anyways, Good luck w/ the car!
  #32
Warrtalon's Avatar
Oh ok, sure. I guess the thousands and thousands of us with MBCs just aren't making as much power. =(
Old Aug 1, 2006, 08:42 AM
  #33
ultraist's Avatar
Yes, it's most likely the MBC. Being that it was holding boost longer then stock on my guage after it was installed and it didn't taper as much. More then likely the boost.
Old Aug 1, 2006, 08:44 AM
  #34
ultraist's Avatar
It's possible that you could, each car is different. I think an electronic boost controller with more options then a manual one with just a spring mechanism in it, is better. With an EBC you can control the boost levels on EVERY RPM, you can raise or lower it how YOU want to, you can tell it WHEN the boost comes in. All those options alone make it better, IMO. Not just that, but they have a higher peak hold. The EBC I saw last night, when in "open mode" could go up to 40+ psi from the factory.
Old Aug 1, 2006, 08:45 AM
  #35
ROK EVO's Avatar
How much boost were you running with MBC before the tune?
  #36
lil'evil_evo's Avatar
I love how people think a boost controller will help power as much as 20whp lol
Old Aug 1, 2006, 08:47 AM
  #37
ROK EVO's Avatar
That's why I asked him how much psi was he running.
Old Aug 1, 2006, 08:49 AM
  #38
ultraist's Avatar
Like 21 - 22 psi, but it held it much longer then stock. Stock it would die out much faster.
Old Aug 1, 2006, 08:50 AM
  #39
ultraist's Avatar
In conjunction with a TBE, intake, and walbro. The fuel pump alone allows more boost to be used.
Old Aug 1, 2006, 09:04 AM
  #40
Rnm
Rnm's Avatar
That dyno reads like a Dynojet. Nice gains nonetheless.
Old Aug 1, 2006, 09:11 AM
  #41
boostedwrx's Avatar
yea its not a DD dyno...
Old Aug 1, 2006, 09:57 AM
  #42
ultraist's Avatar
I appreciate your help maker of dyno's and technical engineer.
Old Aug 1, 2006, 10:01 AM
  #43
Rnm
Rnm's Avatar
No problem, just reassuring you that you are nowhere near 370whp on a Dynojet.
Old Aug 1, 2006, 10:08 AM
  #44
-=SPECTRE=-'s Avatar
Threads like these should be deleted - when noobs come on here and search for answers (like they're endlessly told to do) they're going to get threads like these (full of conflicting information, half truths and outright BS) back as results and will become even more confused and frustrated.
Old Aug 1, 2006, 11:19 AM
  #45
Mekanic's Avatar
+1
Quick Reply: Mustang Dyno Sheet Baseline and w/ Tune Evo IX.
