INgalls vs Weapon R...dampeners
Kinda hard to come up empty when searching for those two dampers. There's even a full write-up by SPT, the new owner of EvoM.
I have not seen ANY complaints about the Ingalls, but the old Weapon R was faulty and broke on almost everyone. Weapon R then supposedly made a new version and compensated the owners of the previous version. I have not heard anyone really talk about the new version - most probably just avoided them altogether after the last fiasco and went to Ingalls.
Fwiw, I recommend a $50 front motor mount before either damper, because the damper is just extra weight that tries to compensate for a weak stock bushing. Replacing the stocker with a stronger motor mount eliminates the problem at the source.
....Fwiw, I recommend a $50 front motor mount before either damper, because the damper is just extra weight that tries to compensate for a weak stock bushing. Replacing the stocker with a stronger motor mount eliminates the problem at the source.
Which front bushing are you using, Warrtalon?
the Ingalls is good, I've seen it used on other cars, but they have had problems with the mounting plate bending on other vehicles (cobalt SS/SC)
On the hardest setting you will also get a LOT of engine noise and vibration in the cab.
Can't argue the price, $50 vs $160.
I use to have a Weapon-R damper on my Saturn Ion Redline. Ingalls over WR anyday.
The Weapon-R is non adjustable, It's a soft rubber bushing that wears out fast if launched a lot like I did and has to be replaced by them every 2-3 months if you want the best performance.
WR also had bracket problems on the Saturn Ion Redline application as well, not breakage but fitment..
