"Long Term" Update on 05 Evo
Originally Posted by Ruri
How do you get 27 mpg?
Do you baby your Evo?
Originally Posted by sonicnofadz
Seems like you have an oil leak or something. Do you have any built up oil residue on or around the oil pan or anywhere underneath the car? Try using the UV oil dye + blacklight to locate any leaks.
Originally Posted by hillbilly8R
I actually only got that one time on a long trip, usually get closer to 22mpg. The 27 was actually on some interstate speeds, around 70mph on half and 55mph on the other half (for the tank) about 2 1/2 - 3 hour drive. That is the only time it got that high, most of the highway miles I will get about 25.5mpg as the highest. That was babied for the 27mpg, just trying for a mpg high!
Charlie
almost 20k on my 05... she treats me better with every mile i put on her...
works short shifter and bushing kit fixed that morning sickness you were talking about w/ the shifting...
and i would love to see 27mpg on the highway... haha! too bad i don't have the patience to do 55.....
to the OP, you might have something wrong. I've had two evos and niether of the used oil like yours. Actully my oil level was always full, when It came time to chage it. Also, I change my oil every 2500 miles.
Like I said above, I've had two evos. I put 15.5K miles on the VIII and had no problems besides a little bit of rattly plastic. THe IX now has 9.5 K miles and also, no problems cept a little rattly plastic.
EDIT: Oh yeah, shifter was notchey and rough at first, but that went away on both, right around 7-9K miles.
The few things I have done to the Evo 8 MR after having it for 22 month:
- Change the clutch at 11000 miles
- Change the tires at 10000 miles
- Stock suspension got destroyed beyond recognition when I had the Tein H(2" drop) on my stock Bilstein struts/shocks
- I had to buy a new set of tires and suspension due to the cathastropic damage caused by the cheap *** Tein H springs.
- Change the ACD oil at 11k miles and came black
- Brakes never made noise.
- Shifting was notchy until I put GMshyncromesh
- After putting a Exedy Twin Disc clutch the car is very rough when launching the car slowly in first gear. Car shakes inside and outside(engine) a whole lot when shifting to first gear
Carlos
Carlos
No residue or leaks, you must not have got your evo brochure, it is normal for your "high performance" engine to use oil. At least it consumption has slowed as it breaks in. Usually notice consumption after being in the turbo more frequently. The S2000 actually used about a 1/4 quart for it's first 3,000 miles, but it has not "used" anymore. To give some credit to evo, the S2000 manual also states it is normal to burn some oil.
Chill dude.....I am sure he was just trying to be helpful! I own a 2003 evo 8 and my car doesn't burn any oil? I am lucky if I add 1/2 quart every 2 months. I guess it also depends on how hard the car is driven also......
it's normal for any engine to consume oil during really hard driving, such as a trackday. If it's consuming abnormally large quantities, I'd be worried, but a 1/4 or 1/2 quart between oil changes is not excessive by any means. Now, if I lost 1/2 quart after only daily driving driving and freeway driving and never hit mid or high boost, I'd be worried.
