Help me with MR Temp Gage swap..
Yes I have searched... Mabey Im in the wrong forum but I wanted all you smart people to see my post & help me with your knowledge. I installed an Autometer Electromic Temp Gage in place of the factory gage on my MR. There are 5 wires from original gage. The wires are as follows,
yellow = pos. for light,
black = ground for light,
red = pos. for temp gage.
There also is a white wire & a white wire with blue stripe. My new Autometer Gage has 3 tabs. 1 for positive, 1 for sensor, & 1 for ground. I have the red wire to the positive on gage. I have the ground tab connected to a ground wire to the body (checked continuity & its definatly grounded). I have tried the white wire & the white wire with blue stripe on the sensor tab & both wires together. When I turn the key on no matter what the needle on gage moves to about 140 deg. farenheit & stays there no matter what the oil temp. I plug the factory gage back in & it works fine. Am I doing something wrong? What wires do I use? Will the factory wires even work for the Autometer Gage? If I cant get a reply that works I guess I will put in the temp sensor that came with the gage.
Thanks for the input! I needed at least a 35 lb. boost gage so I bought the 52mm three gage panel fom Grupp-S & some Autometer Gages from another vendor. Thats why Im switching out the stock MR gages. The panel looks awesome in the car with the gages angled toward the driver. I guess I will install the sensor that came with the gage so I can have accurate temps.
05graphiteMR
For Sale - Cars For Sale
12
Mar 7, 2009 01:12 PM
Nvr2old32
Feb 15, 2006 05:19 PM
