Power Numbers
Power Numbers
Right now i have a RS*R catback exhaust, RnR upper piping, AEM intake, Greddy Profec B Spec 2 boost controlor (15 psi low boost, 23 psi high boost) DC Sports downpipe (on order should be in tuesday). I might be gettin a tune at the end of this month or maybe next depends on when the tuner comes. What numbers you guys think i will put with and without a tune. As soon as i get it tuned and a dyno i will post up the numbers.
No, it's 20.3psi peak and tapers to 17psi. 23psi is retardedly high for not being tuned. That combo of mods is not good either for a car that's not tuned. I'd turn that boost down to near stock if I were you. There's also no reason to run on your low boost setting. Why would you have it set to 15psi? That doesn't make any sense either.
As for the dyno numbers, look...why bother asking? We have people ask this junk all the time as if we can look in our crystal ball, and they don't bother looking to see what everyone else already has made with those same mods. It doesn't matter what we say. You will see when you hit the dyno.
