build my 2.0
Old Aug 13, 2006, 05:50 PM
GT35REVO8's Avatar
build my 2.0
what all do i need to build my 2.0?which pistons and rods do you recommend?was gonna start my internals and get AMS VSR intake mani and 75mm throttle....wanting to up my boost and get in the 600awhp range...and i think this is the best way to do it...thanks for your input..oh and can you put a website were i can get the parts at a decent price...
Old Aug 13, 2006, 06:46 PM
jmartinez1170's Avatar
I would recomend the new wisco 1000+hp pistons and oliver rods. I would also get the new eagel crank. Depending on how many miles you got on your motor you might need a new oil pump. You also need a head gas., head studs. If you dont have a clutch i would get twin plate or better.
Old Aug 13, 2006, 06:52 PM
hotrod2448's Avatar
Since you are going to placing an order with AMS and you have their GT35R turbo upgrade why not just ask them what they recommend? I'm sure they will be better able to guide you than a bunch of people on the internet that you don't know if they know they *** from a hole in the ground.
Old Aug 13, 2006, 06:53 PM
If you want to hit the 600whp mark your going to have to port you head out 1mm with a dual spring setup. Bring the rev limiter to 9200 if done right. Drop thouses hks 272's and get some cosworth m2 cams with have 11.0 lift and both sides plus a set of cam gears to fine tune the idle and power band. If you can get some which it is super hard to get over here is hks 120oct race gas so you can bring that boost up to 32psi. And you will for sure hit over 600whp if not use a lil bit of alk/meth. Top off with a crazy soild tune and you will love your car.
Old Aug 14, 2006, 12:46 AM
GT35REVO8's Avatar
well i have 117 octane i can get,already tuned for it...im goin with ams race head,oliver rods,new crank and pistons(not sure which companys tho...and lose my hks 272's and go JUN 272s or the cosworth....right now i redline at 8000..so id like to hit 9200 rpms or more,600+hp and 33psi or higher would be a good goal...is 28 psi on a 35R with 117 octane a good boost level?can i go higher?im set for 21-22 on pump and 28 on race...thanks
Old Aug 14, 2006, 02:33 PM
You know that your not going to get there with just adding thouses parts there is something your missing. You might have 1000cc injectors but without a dual fuel pump setup or a fuel cell setup with a higher volume pump you going to max out at 540hp.
Old Aug 14, 2006, 03:03 PM
Vivid Racing's Avatar
I would personaly suddgest a stroker motor;2.1(destroked),2.2,2.3,2.4. I had a GT35r on a 2.0 VIII and i also drove a friends evo with a 2.3L and same basic mods with a 35r and his was way faster and more responsive!!!! it very important to focus on engine response than just top end or bottom end. If you can build your engine to build the same amount of power earlier and longer you will be more pleased with the results. The 2.3 does just that and it will allow you to hit the 600whp mark... Vivid Sell and builds them but also AMS can also build them both very reliable and strong motors. Good Luck let me know if you need hooked up!
Old Aug 14, 2006, 03:08 PM
GT35REVO8's Avatar
i want the ams stroker..only thing is to install one is CRAZY money way more then the stroker itself...talked to AMS they said 5Gs to install....anyone have one already built that wants to sell it?or have anything already built i can pick up..??
Old Aug 14, 2006, 03:49 PM
Installed? in and out of the car? AMS builds many strokers and very successfully. So they can ask that price. Vivid has created there own stroker kit that has been tested on many but not aswell known as other.
http://www.vividracing.com/catalog/p...ducts_id/16133
But all depends on what you all want done. Let me know i can help.
Thanks!
Old Aug 14, 2006, 04:33 PM
lbcevo's Avatar
The $5000 AMS quoted for installation includes the stroker parts and assembly, right?
You should be able to take your car to your local indep. Mitsu mechanic, have them pull the motor, ship it to AMS for stroker short block assembly, then reinstall, all for about $5000. Removal and reinstallation should cost about $1300, AMS stroker is $3250.
Old Aug 14, 2006, 08:50 PM
GT35REVO8's Avatar
no the AMS stroker is $2000...and i asked what there price is for install so i can get a idea,and they said $5000...cus you have to do some major work,blueprint,etc...so $7000 for a stroker...but ill keep lookin or save my pennys
Old Aug 14, 2006, 09:26 PM
RREvo's Avatar
No you didn’t understand them, the $5000 is probably the quote for you to bring the car to them so they can pull your motor install the 2.3L motor, so the 2.3L motor and labor would cost you $5000.
Old Aug 14, 2006, 09:42 PM
GT35REVO8's Avatar
heres what happened
Me; would you recommend a stroker with 35R?
AMS:depends what your looking for
Me:how much is stroker?
AMS: $1995
Me: what about installation price so i can get a idea for shops here
AMS:hold on......we charge $5000 to install.because we have to pull the motor send it out to other shops,and its a lot of work...
that was the conversation..but he said $5000 for INSTALL...and a shop here told me about $4000
Old Aug 15, 2006, 10:19 AM
I just talked to my tech. we have a shortblock here ready to build and ship if you want it. If we have your car and we build your motor and get installed your looking around $4500 for the price of the kit installed you driving away kicking some trash.(complete) Just PM if you have any questions.
Evan M Smith
Old Aug 15, 2006, 10:47 AM
4TUN8's Avatar
I need a motor soon, but I'm going to have my boys at TurboTrix Racing do it =)
Check them out if you're curious, they do awsome work IMO.
