HELP! i think i need a new CLUTCH! =[
just have someone that knows what they are doing look at it.. the last thing you probably need is messing anything up more that it already is... (if it is even messed up at all)
and FWIW, if your clutch is slipping, your RPMs would be shooting through the roof but your car wouldn't be moving very fast...
Originally Posted by M1chael322
No i kno what im talking , its the techometer the needle stays still for a second at curtain HIGH Rpms , DO you think its my clutch that is broken soo then its not grabing, my friend told me to go get a new clutch and a preasure plate
well if your clutch was going out your speed would not increase in relation to your rpm's...i dont know what your issue is...but i dont think it is the clutch...if it was the rpms would go up faster adn you would not be accelerating while your rpms rised. unless there is some crazy thing that defies logic
Ok but can some one be more detailed and be more specific about how to test if my clutch is really broken, one tells me to red line 5th , the other tells me to roll at 40mph and throw it in 5th gear , one tells me to red line 3rd gear, but no one tells me what to Expect after i do it, should i expect my techometer to like jUmp up out of no where, or stay still or what. CAn some one please be more exact in details and explained things more clearly step by step and what to expect. PLEASE and THANK YOu i apreciate you guys for helping me, i am a newbie at these clutch stuff
-Michael
-Michael
it just sounds weird to me that your rpms do not advance and then all of a sudden the clutch grabs...your rpms should be going up higher and oyu should smell some clutch if it was the clutch...i dont know though that sounds like a strange issue
Originally Posted by TTP Engineering
Clutch is done, your rpms are slipping, holding then grabbing. Driving a slipping clutch will further accellerate wear.
You have about a week before you won't be able to drive anywhere.
Send me a PM and I will give you some clutch options to fit your budget.
(car got dyno'd) nobody could drive it, claims it was supposed to be that harsh.. Is this true? whats the driveablitly compared to exedy twin plate?
WOW!
Just put it in 5th at < 40 and floor it. If the RPM starts rising disproportionately to the MPH, it is slipping.
slippage will be most evident when there is most load put on engine. the higher the gear, the more load there is on an engine. 5th or 6th (MR) will be the best gear to test.
that's why I said the highest gear not knowing what model you had. You want the most load on it which is not third or fourth gear
OK well i test out my clutch in 5th gear this morning and yes my clutch was sliping so im guessing i have to replace a new clutch, Im thinking about getting a competition puck clutch. Well any ways, I apreciate every one for helping me, giveing me advice and tips. THANKS to everyone
Now i need money for a new clutch -_-
-Michael
-Michael
i think my clutch is slipping also, i tried the 5th gear WOT and the speed goes along with the rpms but when i hit boost my rpm would jump like 1k and drop back to normal and launch. this happens on every gear, but when im off boost the clutch grabs fine..hmm is it the clutch slipping or a boost leak? car drives fun except when i hit boost the power just isnt there.
