Question About Bushur Stages
The Stages vary with the power you get from each.
The largest increase in power is from the Stage 1 kit. This opens the car up to breath and gets the base flash in the car.
Stage 1 comes with:
BR full 3" turbo back, mandrel bent stainless steel exhaust. Weighs in at 23.5 pounds for the entire system, lightest, highest flowing on the market. You get a choice of any of our 3 mufflers and an offroad pipe or highflow cat.
BR manual boost controller
BR boost gauge and mount
BR Stage 1 flash
BR air filter kit
This kit will typically add 70 whp to any year EVO, as long as everything is in good working order. It's $1350 for the entire kit.
The Stage 2 kit is around 15 whp.
The Stage 3 kit is around 30 whp.
The Stage 4 kit doesn't add any whp, it does add a margin of safety with the fuel pump and most cars do not need the injectors if they are running the stock turbo or a small upgrade.
Thanks for asking.
Stage 1 comes with:
BR Stage 1 flash
BR air filter kit
Thanks for asking.
Dave since you are here got a guesstimate for the whp gain with your race fmic on a camed stock turbo 05 EVO with all the usual supporting mods? It's been a point of debate with my friends. Highly recomend the BR stages by the way, often imitated never duplicated.
Jm538051
Cobb AccessPORT
10
Jan 23, 2014 11:31 AM
JebusMKIV
Apr 1, 2010 07:12 PM
