hp numbers
hp numbers
can anyone post hp numbers from theres 03s or 04s with these mods
turboback
mbc
some intake or filter
only 19 or 20psi
custom tune
fuel pump
with or without cams
turboback
mbc
only 19 or 20psi
custom tune
fuel pump
i don't know a single person who runs boost that low. i made 324whp/368tq on a Mustang Dyno (calculated 30% loss)with a slipping clutch, but that was spiking to 27PSI tapering to 23 by redline with an AFR of 11.5:1...
Originally Posted by blakevo8
its a simple question i wasnt asking for that or someone to tell me to search, just numbers
If you don't want to be told to search, then always search FIRST before posting. Incidentally, it's one of the forum rules.
turboback
mbc
only 19 or 20psi
custom tune
fuel pump
turboback
mbc
only 19 or 20psi
custom tune
fuel pump
Originally Posted by SASD209
5,000,000 HP. Could you be more vague?
warrtalon....you have got to be the worst person on this site...the guys askin a simple question,all you ever say is Research it....you probably dont know the difference between your head and your ***....people come on here to ask for help or simple questions and all i ever see you say is "research it",or "are you serious you gonna ask that" you probably have a lancer es that has evo stickers on it,lol
housedj...you ran 27psi on a stock motor and pump gas??wow thats retarded..anyone will tell you thats too much maybe with alky,and maybe you have that if not,then your motor and rings will be shot.
at 19 psi with below listed mods i'm between 250-260 hp w/ 260 tq.
EDIT: Mustang dyno from mynes performence in mesa, az, if i remember correctly.
Edit: Also anyone who posts up numbers, you should include the type of dyno you were run on. So the original poster doesn't go into shock if his vary from yours.
ok??you make no sense...of course a evo cant run 27psi on straight pump..but your running 104...
cheers.
Mike
