Boost Taper.
As for the HP TXS Boost Controller, they re-did the entire design. it used to be an alan wrench adjusted unit with a little bit different internal-workings. Now it's adjusted by simply turning the top negative or positive, it's a LOT better. They just recently updated the design.
" High Perfomance Boost Controller (BC-HPBC)
Utilizing a uniquely engineered ball/spring mechanism combine with an adjustable bleed valve, the BC-HPBC allows you to spool your turbo to full boost up to hundreds of RPM faster than stock! The adjustable bleed mechanism lets you minimize the massive boost "spike" that can occur with poorly designed ball/spring manual boost controllers. "
There's not really anything for the Forge WGA to help.
The TXS MBCs in no way compare to the Hallman or Forge UNOS. They do not work well at all, so not sure where that sentiment came from. You can read countless threads on people ditching their TXS for a Forge or Hallman BECAUSE of the bleed hole (it's a negative thing, not a positive).
He wasn't tuned in 4th and 5th gear, I'm sure. I'm also sure you've seen people hit that on 91, but that doesn't mean it's a good idea.
Originally Posted by Varrius
My car was tuned to spike 24psi in third gear on a Mustang dyno by Jestr Tuning. You can speak to him if you want to call him a "liar."
I have the TurboXS HP Boost Controller. I tried a Forge UNOS, it didn't hold boost as good. It could be my car, too. Who knows. But, if what Warrtalon is saying is true, I will leave it a lone. By the way, this setting was made by John with Jestr, I have not touched the boost controller, as he told me not to, since the tune. Also, another question. If I get the Forge WGA, it won't help me, at all?
I think the bottom line is that boost taper is normal. There are ways to try to make the turbo hold higher boost but that doesn't mean its better for performance. The turbo can only flow X amount of air. Running it at a higher boost level will probably do more harm than good. Spiking to 24 is acceptable if tuned for it but I agree with Warr that running 25PSI in taller higher load gears is probably not a good thing. I would be willing to bet he is getting knock and timing pull. I would be interested in a log of timing during a high gear pull.
