Small shutter at low speeds when turning
Hey guys, when coming to a stop sign or whatever, when turning left or right the car shutters or vibrates a little then stops after i complete the turn, but it also only does until about 2000 rpm then stops, i changed my drivetrain fluids last week and used recomended oil's, any ideas, hopefully not my transfer case, thanks
Bump, Mine as well. Is this just a normal thing with this car. It only seems to happen some times though, or at least I notice it sometimes. It's not a huge shutter, but enough to grab my attention a bit.
you might have used the wrong rear diff fluid. this should be happening particularly badly when you parallel park and you can hear it sometimes.
what you need to do is either change your rear diff fluid again with the proper fluid or add friction modifyer into the existing fluid. i suggest the former.
well that was useless
it seems to happen to me when i pull out of my garage in the morning and wheels are turned but ive found giving her a few mor rpm's helps.
mine has done this from day 1 but i tend to not give enough r's due to being used to a gobb of low end torque (mustangs)
anyonewith more info sheptrans maybe???
RED DEMON
18
Jul 27, 2015 06:38 PM
sno_evo
25
May 11, 2015 12:09 PM
Joes06MR
14
Sep 14, 2007 03:45 PM
