did i put the BOV in the right direction
i have an APS and i put it in and it doesnt sound loud, thus im to believe i put it in right, because i didnt want a loud bov. If you tried to push the bov open with your finger, that outlet is going toward the intake, and the side that opens after you push that side is facing the turbo? if i did it right, i thought that it would be the other way around seeing as the psi of the turbo opens the bov right? thanks everybody!!!!
Say what? You said one side is facing the intake and one is facing the turbo? The intake and turbo are the same direction relative to the BOV. The valve side should be connected to the UPPER INTERCOOLER PIPE, and the blowoff side should connect right into the MAF pipe (intake pipe).
lonestarky
Apr 6, 2012 01:29 PM
azredevo
53
Aug 3, 2006 01:30 PM
scottatyamaha
16
Feb 20, 2004 02:50 PM
