why do evos dyno in 3rd gear and not 4th?
Sometimes due to the limited amount of ventilation and cooling for the car on the dyno it is pulled in 3rd gear because it will generate less heat and allows more pulls with more accurate numbers (because there is less heat build up). 4th is a longer pull in a higher gear so there will be alot more heat generated (and lower dyno numbers).
what gear you are in does not effect HP readings in anyway. IT DOES effect torque greatly tho do to the gearing. 1:1 ratio is what is is "supposed" to be. What gears do is multiple torque thats why u get a different reading or TQ only is different gears. THe lower the gear the higher the torque output.
Most shops will do 3rd gear pulls because of the speed required to tun a car to redline in 4th gear, no to mention that with low hp/tq cars a 4th gear pull can take a very very very long time.
You can always request a 4th gear pull, tune. I do as i need to know my AFR's a the end of the 1/4 with close to the correct load.
Originally Posted by boostedwrx
On my 5-speed I was always tuned in 3rd, with my 6-speed its been tuned in 4th. Never asked Shiv why...
