stupid Insurance Companies! Need Recommendation ASAP!
Old Sep 5, 2006 | 12:32 AM
.MM's Avatar
.MM
basically the situation is this:
my stock advans have like 6k miles on them, they dont look too worn down, but its hard to tell
i had the passenger side rear tire get torn and ripped...
so now the insurance company will only cover the damaged tire
i explained to them and sent them a copy of the manual stating that the 4 tires on the car need to have matching thread and that replacing just one tire is bad for the AWD system on the car
the tire being ripped isnt my fault and the person who is at fault, their insurance is covering the costs. BUT, he has the same insurance company as i do
basically, what should i do? the insurance company is claiming that they only have to cover what was damaged and that they will not replace the other 3 tires along with the damaged one
should i make a big deal about this? will the 25% thread difference on the other 3 tires hurt the car?
should i call State Farm YET again and talk to a supervisor and go off? threaten to sue?
im lost on what to do
thanks
matt
Old Sep 5, 2006 | 01:28 AM
EiEVO's Avatar
not to argue...But why would they cover a wearable item anyways? Just like brakes....They are wearable. I say take what they are willing to give you. Honestly dont push your luck cause im sure they have the type of software where they can put in notes and save information on every client they have for this reason. My reasoning: If they put a note/information in thier system stating your being a PITA and if you ever have a issue down the road i dont think they will go the extra mile to help you out when you really need them to.
Work with them... Try to get them to pay for all new tires and you will pay for the mounting and balancing.
Old Sep 5, 2006 | 01:54 AM
fromWRXtoEVO's Avatar
.MM
I find rare that a insurance company is willing to deal with wear and tear parts. As far is the ACD, I don't think it would be as sensitive to detect such changes.
From past experiences I know for a fact that changing the tires size on the front or rear axis only could and would cause to set off the Active center differencial.
I once changed tire sizes in the front on a Porsche Carrera 4 and the car couldn't run over 25mph, the ECU kept shutting off the car.
I don't think this is the case though, I went with completely different size tires only in the front but a worn tire should affect that much.
just my .2c
Carlos
Old Sep 5, 2006 | 01:58 AM
jab_phoenix's Avatar
this is just me... but if your that worried about it i would just go with new tires, you can try and get the insurance company to spring for it by using the "its an all wheel drive car and it creates an unsafe driving situation, which could lead to another accident possibly costing you thousands of dollars" and if they dont go for it just spring for the tires yourself, i know that its an expense but winter is coming up anyway and its about time to get some winter tires anyway. Plus luckily they are the stock tires and not some expensive yoko's or something along those lines... just be glad all you lost is a tire ^_^
Old Sep 5, 2006 | 02:03 AM
evo637's Avatar
threaten to sue for tires? Damm just get yourself another pair if they will only buy one. Honestly your lucky the insurance company is even hearing you out for just tires.
Old Sep 5, 2006 | 10:15 AM
.MM's Avatar
.MM
well, it was actually the entire rim and tire, because the guy who hit the wheel ripped the tire in half
and whoever said "your lucky it's only the stock tire and not some expensive yokos..."
the stock tire IS an expensive yoko....
my problem is, the insurance company is replacing the one damaged tire and one damaged wheel only
i dont care about the wheel
but, replacing one tire with a new one, when all the others are worn down, according to the manual and the dealership is Bad for the AWD system and differential
causing heat and damage...
comments plz
Old Sep 5, 2006 | 10:24 AM
KevinD's Avatar
Originally Posted by jab_phoenix
Plus luckily they are the stock tires and not some expensive yoko's or something along those lines... ^_^
luckily? your joking right. the stock tires are over 300 dollars a tire!! they ARE the expensive Yokos.
Old Sep 5, 2006 | 10:25 AM
PessimiStick's Avatar
comments plz
There's pretty much zero chance that you will get the insurance company to replace all 4 tires. Take the one they offer and buy 3 more yourself, or just drive it with 3 and 1. I can't comment on any effect it may or may not have on your car if you go with 3:1.
Old Sep 5, 2006 | 10:28 AM
~$250 per tire actually, but I'm pretty sure he was being sarcastic.
Old Sep 5, 2006 | 10:35 AM
evo1337's Avatar
just wondering how he hit just the tire and rim on the rear? no other damage? just tire and rim? got pics?
also if they only go for 1 tire just get the check and buy a set of used yoko's from someone here. you can almost get a full set for the price of 1 new
evo/X's Avatar
have them buy one i guess.....if you dont pln on fighting w/ the insurance companyanymore.....then buy the other three.........you dont want one 100% tread running with 3 25% tread tires.......but i would keep the other three and keep them or try and sell them.
Old Sep 5, 2006 | 10:38 AM
urBan_dK's Avatar
Simple solution: have the new tire shaved to the same depth as the other four. Problem solved.
Old Sep 5, 2006 | 10:44 AM
hotrod2448's Avatar
Yeah, I'm reading this and thinking "So, it got hit hard enough to rip the tire, bend the rim and, this guy is only worried about getting 4 new tires instead of one."
Don't worry, I'm sure it bent enough crap and knocked the alignment out enough that the new tire will wear out twice as quickly and catch up to the others.
I hope they are fixing more than just what you listed.
As far as the difference in roll out goes I don't think it is enough to worry about but, if you want piece of mind as said above have tire rack shave it to the same tread depth as the other tires.
Old Sep 5, 2006 | 11:09 AM
xtnct's Avatar
Just take the $300 for the new tire, then go to the for sale section on this site and buy a slightly used Yoko for $100 and keep the $200 for your beer - Done deal. If you want new tires, then just buy 1 out of your pocket to at least keep the L&R the same on one end of the the car. You'll be fine, I did that withough any issues.
Old Sep 5, 2006 | 12:56 PM
Golovko's Avatar
thanks
matt
yet another reason why insurance is a big scam. how much money have you wasted in premiums and could have bought tires 10 times over?
