Cams/Timing Belt Installation: Anythign else I should do?
Gonna order this complete timing belt replacement kit from buschur and was wondering if there is anything else i should replace while i am getting this done:
Complete timing belt replacement kit for your Evolution. Includes: Timing belt, balance shaft belt, timing belt tensioner pulley, timing belt idler pulley, balance shaft tensioner pulley, hydraulic tensioner.
Also gonna order some cams & prolly cam gears. But are there any seals or gaskets or anything else i should go ahead and order?
Thanks
-Ryan
Thanks
-Ryan
You are going to want the tool to push back the hydraulic tensioner- basically a long M8 bolt. Or M10- I can't remember. Anyway, you should have that on hand. You can make one out of a piece of good quality all-thread if you want.
edit: if you're going to change cams you will want to replace the cam oil seals.
Make sure you don't knock your oil pump balance shaft out of sync. a Mitshu mechanic did mine (belt/cams) and it was out of sync, and wreaked havoc for 4 months!! Busting stuff like crazy. look up my post on that. the marks WILL still line up, even if OFF 180 degrees! So be careful!!
Evo47
Nov 8, 2016 02:28 PM
AboodsEvo
Nov 19, 2010 06:21 PM
evane
22
May 16, 2010 05:20 AM
MJ23FE
Jan 25, 2010 05:10 PM
