Getting melted plastic of off a muffler?
Ok, I have full megan turboback, and the catback section exits my rear bumper to far to the drivers side, oh well ill get over it, However it melted my bumper on that side, which I didnt really care about the inside piece of the bumper that noone can see anyhow. My SS exhaust shield arrived today, and when I took off my muffler, i figured the plastic would peal or chip off easliy, i mean its just plastic melted onto smooth metal? Not the case, this stuff is stuck on good, Im just wondering if there are any household chemicals that will take it off of my muffler tip. Goof off maybe? also stuff that wont discolor the muffler tip. Thanks ahead of time for any help.
Originally Posted by eve-slow
Try some alcohol based products, and let it sit and dissolve the plastic.
The problem is after some nice spirited driving, with the muffler mounted on the car, it is to deep behind to bumper to get to it, and the muffler being about 500 degrees or w/e it runs at is kinda hard to get off. I got some acetone and some rubbing alchhol, ill see what happens.
a small propane torch, just don't keep it on there for a long time or it will start to discolor the muffler. Just slowly run it back and forth for 15 or so seconds and it should come right off.
well, acetone, gasoline, mineral spirits, and a razor blade barely touched it, however they did remove the very thin layer of plastic that was fartherst towards the end of the exhaust tip, you can barely see the melted plastic unless you get right behind the exhaust and look for it. I was going to try a torch but I was afraid to discolor it, If you hit it with a torch and then wipe away the melted plastic it should work, but im to lazy to try it, and a gallon of gas and some other cheapo chemicals were all I was going to waste my money on. If I get home to boca anytime soon I have a butane torch in my garage, so Ill try it then. Im thinking of getting a custom axel back section made with just a magnaflow tip and no muffler, I kinda like the loud annoying noises my car made when I was driving w/out a muffler.
I used a razor blade very carefully and shaved off layers of it. Then followed that up with an SOS pad and polished it up. The SOS pad will take off the remaining plastic. Hope that helps.
