just received my hallman mbc!!!
Old Sep 13, 2006 | 11:29 AM
dafunk630's Avatar
hey guys,
just wondering at what psi should i adjust the boost controller at???
-thanks
Old Sep 13, 2006 | 11:32 AM
Evo9"Miss Rose"'s Avatar
23psi safely if your on Pump if on Race then maybe 24-25psi??? some one correct me if im wrong!! BUt i think 23psi would be your best bet
Old Sep 13, 2006 | 11:55 AM
evolrobert's Avatar
what should he set it at if he was using a stock fuel pump with a tbe and intake filter and flash?
Old Sep 13, 2006 | 12:02 PM
sparky's Avatar
Stock Ix pump is good for your level of mods. Max boost will depend on octane of fuel. 22-23 is good for 93 octane(R+M/2). Intake kit will lean it out, but the flash should've corrected for it.
Old Sep 13, 2006 | 12:21 PM
dafunk630's Avatar
on 93 octane
Old Sep 13, 2006 | 01:12 PM
DanJ's Avatar
In what gear do you guys usually adjust it at? Do you guys do pulls in 3rd gear to adjust it?
Old Sep 13, 2006 | 01:27 PM
shbomb8188's Avatar
i set mine in 3rd.
Old Sep 13, 2006 | 01:38 PM
Rnm's Avatar
Rnm
Originally Posted by shbomb8188
i set mine in 3rd.
Yep, I set my boost in 3rd as well to spike 23lbs on 93 octane.
Topic creator: You should really look into getting some sort of flash to take advantage of all your mods, then it will really wake up!
Old Sep 13, 2006 | 02:27 PM
dafunk630's Avatar
how did it feel after u got it flashed!
Old Sep 13, 2006 | 02:37 PM
sparky's Avatar
i set mine in 3rd.
It's probably a different experience on a IX. On my VIII I adjust max boost in top gear, as my boost'll creep a bit in 5th and not in 3rd.
Old Sep 13, 2006 | 02:38 PM
evolrobert's Avatar
Say I have a tbe with a filter and then i had it flashed, then i decide to install a mbc do i have to have ecu reflash again?
Old Sep 13, 2006 | 05:42 PM
Rnm's Avatar
Rnm
Like a cammed Evo8.
No, as long as you keep the boost the same as before.
Old Sep 13, 2006 | 05:45 PM
justchil's Avatar
Damn already beat me to answering... I say 23psi and set it at the coolest part of the day/night in 3rd gear.
Old Sep 14, 2006 | 12:00 AM
SophieSleeps's Avatar
What does the car spike to in stock form? sorry for the newbie question.
And why can't a flash re-adjust the wastegate to stay at 23psi?
Old Sep 14, 2006 | 12:06 AM
EiEVO's Avatar
If you know your question is a NEWBIE question then why did you post it anyway... You should learn quickly that there is a seach button at the top of the screen. As for your question: Normally stock Evos spike 19 psi and taper down as the RPM's rise. As for how low... many see it drop to roughly 13-14 psi. Obviously the elevation and climate makes a difference. As for a re-flash. It doesnt adjust the stock wastegate. Wastegates are mechanical not electrical.
