Switching the radio with the stock gauges...
Old Sep 16, 2006, 03:55 PM
JakexTrainer's Avatar
Can anyone give me directions on how to switch the stock MR gauges with the stock radio... info on where the screws are or pics would be awesome
Old Sep 16, 2006, 03:56 PM
SRT-TO-EVO's Avatar
Check the how-to section. It's there somewhere.
Old Sep 16, 2006, 04:05 PM
Cant find that post
Old Sep 16, 2006, 04:13 PM
wroblewskievo's Avatar
Do you have the radio relocation kit? I think ams sells them or your dealer can order it. Once you get that it is pretty easy.
Old Sep 16, 2006, 04:18 PM
evrblazin's Avatar
No relocation kit is needed with the MR or RS.
Old Sep 16, 2006, 04:21 PM
evrblazin's Avatar
To the OP I found the link on one of the Cali evo forums... if I find again it I will post the link.
Old Sep 16, 2006, 04:22 PM
Are you sure? The salesman gave me mine when I bought the car so I used it. Good thing I didn't pay for it.
Old Sep 16, 2006, 04:26 PM
evrblazin's Avatar
yea I swapped mine like 6 months ago with no kit
Old Sep 16, 2006, 04:30 PM
alloyic_rs's Avatar
i never used a relocation kit in my rs, all of the necessary radio mounts are already there
Old Sep 16, 2006, 04:33 PM
2Devious's Avatar
I can confirm, nothing extra is needed for the MR. Did the swap last week myself. I just PM'd instructions to someone the other day. Here ya go:
Look at the gauge panel. Look at the lip above the gauges. You will see 2 screws pointing up. Remove them.
Pull the shroud straight out away from the gauge panel. It might be tight, its held in by 2 snap clips on the bottom.
Remove the screw from each corner of the gauge pod, 4 total. There are black plastic shims behind the panel that the screws went to. Set them aside. They will go in that same location when you put the stereo there.
Pull out the gauge panel. Mark each connector going into the gauge and then mark the gauge itself. (for example I used 1 2 3)
Disconnect the connectors and pull the tube off the boost gauge.
Pull off the HVAC knobs. Behind the two outermost knobs you will see a goldish screw behind each (2 screws total). remove them.
Pull the shroud straight out from around the HVAC controls and the stereo. It is held in by a few clips.
Remove the 4 screws holding the stereo in. Leave the brackets on the stereo.
Disconnect the antenae and the plug going into the stereo.
Relocate the gauge connectors and the boost hose up to where the radio use to inhabit.
Move the radio plug and antanae cable down to where the gauges used to reside.
Reconnect/install everthing in reverse. Remember, the two black plastic shims get installed behind the radio in the lower position, just like they were when you removed the gauge panel.
While you have the gauge panel out you can re-arrange the gauges to put the boost gauge closer to the drivers seat. Just remember to look at your marked connectors and install the correct connectors to the right gauge.
Old Sep 16, 2006, 04:34 PM
That's good to know. I'm curious why you can do that on the mr and rs and not the gsr?
Old Sep 16, 2006, 04:37 PM
althemean's Avatar
there were mount brackets that came with the relocation kit for the radio that I needed when I did my swap. Its been so long though I really dont remember. I think I got the kit from 500whp.com for like $50 or something.
Old Sep 16, 2006, 04:41 PM
morgo333's Avatar
cause they come stock with gauges?
Old Sep 16, 2006, 06:23 PM
Geese1's Avatar
Originally Posted by JakexTrainer
Cant find that post
You really need to look a little harder. Took me all of 2 seconds to find it using the search feature...
https://www.evolutionm.net/forums/sh...t=gauges+radio
Anyway, here you go.
Old Sep 16, 2006, 06:36 PM
Hey guys,
Couldnt find that post so i winged it...
You dont need any relocation kit.... this was so easy to do.. im 15 and i installed it with no problem or instructions
