More issues with my Evo (pics)
Well, I guess my car is mad at me for some reason becuase if it's not one thing it's the other. Well, after realizing my TC rear seal was leaking, I noticed another problem when I came home the other night. After I had turne my car off I heard some sort of "sizzling" or boiling noise. I opened up my hood and the spot that is pictured had some sort of fluid bubbling and fizzing due to the extreme heat of the manifold.
I obviously had to let it cool down and then I went to inspect it. This is def engine oil. Now whats wrong with her?
Thanks.
Thanks.
Originally Posted by justchil
That's not good. Do a compression check ASAP.
Is the oil feed line right above where you're noticing this?
I hade that problem when I change my head studs with ARP until I cycled it and re-torqued. Then it went away.
Pull your plugs and look down in the cylenders and make sure there isn't any oil on top of the pistons or cracks... Then do a compression test.
Nope. This is right next to the first runner. I had studs put in not too long ago. Could this be the cause of it? Especially if the head was NOT removed?
We may have a winner.
Ding ding
Doubtful that line would leak unless it was messed with... sounds like you've found the problem
