Headlight Wiggle
Old Sep 29, 2006 | 08:45 PM
EvoBlade2000's Avatar
Headlight Wiggle
So I'm sitting in traffic and I notice my headlights are adjusting up and down. I always keep them on 0 since they aim way too low before i lowered the car.. Somehow my headlights decided it was time to go up and down by about 2 degrees or so, continuously. I dont know why. When I put them on a setting other than 0, they stop moving. Has anyone else seen this?
Old Sep 29, 2006 | 08:51 PM
vwjeff's Avatar
There have been a few threads on this, try a search. One of them was from not very long ago.
One guys car was doing this and he took it to the dealer and they put a $1300 headlamp assembly in it to fix the problem... something to do with the adjusting motor.
Old Sep 29, 2006 | 09:29 PM
evolution_racer's Avatar
^^ That was me. I've posted on this before when my passenger side light was moving up and down. Mitsu replaced the entire assembly under warranty but until you can get that fixed, put the switch on "1" instead on "0" and it should stop it from adjusting.
Old Sep 30, 2006 | 06:05 AM
3SgteGuru's Avatar
Yeah i rember, Fering when Mine are gonna do that. Stupid car. But good luck with that.
Old Oct 1, 2006 | 08:14 PM
I'm not sure what to search for, I tried a couple of searches and didn't find anything. Leaving the headlight on 1 is not gonna work. First of all it doesn't stop the headlights from moving every time (it does sometimes). Secondly they already point too low, because my car is lowered and it is lower in the front in relation to the back, so I cant see anything on the lower settings. I really dont want to buy a new headlight assembly. I would like to get it to the normal position and disable the motor.
Old Oct 2, 2006 | 05:47 PM
SpoonEvo's Avatar
A little off topic...but does anyone know how to adjust the leveling on the HID's?
I lowered my car is it's aiming to low.
Old Oct 2, 2006 | 09:34 PM
RogueSTi's Avatar
I had the same problem...and fixed it by setting the headights to 1...then I manually adjusted the headlights up.
Old Oct 2, 2006 | 09:35 PM
MRCole's Avatar
Search this, huge amount of threads on it. Headlight adjustment is what i did, and found the 3 links that i needed. https://www.evolutionm.net/forums/sh...ad.php?t=75583
Old Oct 5, 2006 | 09:09 PM
It's weird it stops doing it sometimes. It didn't do it at all today. Does anyone know how to disable the motors?
Old Oct 6, 2006 | 03:24 PM
deegaw11's Avatar
im getting the samething but only when it's set on 3.
2FST45O
Sep 26, 2017 07:24 PM
Damian8MR
Jul 12, 2016 07:42 PM
DarkMegaMan
Jun 17, 2014 08:24 AM
2011gts
Lancer How Tos / Installations
Jan 17, 2014 03:10 AM
Nicker31
Aug 17, 2012 03:30 PM
Quick Reply: Headlight Wiggle
