What would it take to make 400whp/400wtq in EVO IX MR???
Originally Posted by Rnm
High flow cat
Thanks guys, I am from the south and a high flow cats are a curse word to us, we have no emission tests so they are pointless, race pipes all the way.
-Nate
Originally Posted by Pure Playaer
How often does meth injection actually blow n engine?
How about if i only run the meth once a week?
Meth is a 24/7 thing it is set to come on at a specifice boost pressure or MAF set voltage and then sprays into your throttle body to cool the Intake charge and cylinders increasing HP and airflow. It isn't like Nitous Oxide in that they can fry your engine. This actually prevents detonation however if your engine depends on it and the pump fails that is when issues arrise. I always tested mine prior to drag racing. When driving normal I turned the boost down to the same level that I felt save on pump gas and had the Meth kit still on which was very safe and kept my HP consistant in all weather conditions.
-Nate
"AZ EVO IX MR" made 337WHP and 368wtq on our MD using Sunoco 104 octane and a custom tune. He's going to do the Cosworth Cams next... we'll see what happens... hopefully he will get closer to 380WHP? He's going with a GT35r next, so i'm sure he will break 400whp with that...
His Mods: ATS Triple carbon, bnb downpipe, Perrin cat delete, greddy ti, ams licp, injen intake, turbo xs front mount, apexi avcr, warlbro 255 ecuflash: 337 hp 368 tq Mynes Mustang Dyno
Mike @ Mynes
Mike @ Mynes
Mike @ Mynes
Mike @ Mynes
-Nate
-Nate
-Nate
would doing this be good?
i dont really want the meth spraying durring daily driving thou.. so i guess i shouldnt really floor it to work n **** right?
blitz drop in filter, turbo back exaust of your chouce and budget, ats triple carbon- thats what i did and love it actually a good daily driver and awesome at the track, and a good race gas flash would get you around 350 on a mustange dyno.
You have to remember when you are asking for horsepower numbers it will vary from dyno to dyno.
There are several ix here in AZ running excellent with these mods and besides the clutch are not alot of money for the power you will get.
As for the 400 hp mark i would wait and see what other people are doing with the new cams that are coming out since there are no hard evidence of before and after dyno numbers.
Turbo trix, GSC, and now cosworth have cams for the IX but i think as of now you can only buy the tt cams.
basically wut i wanna do is have an electronic boost controller n have a really low boost setting for daily driving and a nice high boost setting for racing (and for the meth)..
-Nate
That is exactly why I like the Blitz SBi-D boost controller it can save 4 or 5 different settings. I had it customized for every driving situation that I wanted. As for the meth it only comes on at whatever setting you put it at, but it is completly safe and actually cleans your engine everytime you step on it. It reduces carbon deposits in your cylinders and on you pistons thus keeping your engine young and healthy. Not to mention it is cheap as heck....
-Nate
-Nate
damn man i like how you put everything
but is the forge wastegate actuator thing nessisary?
Ah so it is actually somewhat good
-Nate
OK people. No one should be running meth injection without a good wideband and preferably one with a warning system like the zeitronix. EGT, AFR and or BOOST can be programmed to set off an alarm, LED and trigger a boost cut feature if a failure of any kind takes place.
If you have $400 for a $400 meth system, then you don't have enough money to run meth. You need to put MONITORING equipment such as a wideband ahead of your quest to go fast. Because if something goes wrong, your car will not be fast sitting in your driveway with a rod through the side of the block if you put speed before CARE.
