What would it take to make 400whp/400wtq in EVO IX MR???
#32
Originally Posted by TTP Engineering
OK people. No one should be running meth injection without a good wideband and preferably one with a warning system like the zeitronix. EGT, AFR and or BOOST can be programmed to set off an alarm, LED and trigger a boost cut feature if a failure of any kind takes place.
If you have $400 for a $400 meth system, then you don't have enough money to run meth. You need to put MONITORING equipment such as a wideband ahead of your quest to go fast. Because if something goes wrong, your car will not be fast sitting in your driveway with a rod through the side of the block if you put speed before CARE.
do u guys sell one?
pm link? =)
sorrys for all the trouble
#33
Originally Posted by Pure Playaer
where can i get a good wideband?
do u guys sell one?
pm link? =)
do u guys sell one?
pm link? =)
#34
-Nate
#35
Where in central Florida are you located? Do you guys do dyno and street tunes and if so how much to tune my MR with the listed goals? I need you Zip, address and phone # to see about planning to get to you. Everyone else is too far away and I like what your MR is doing also. I also want to get my car up and ready before the winter months so as to get the best times out of her at the strip.
-Nate
#36
It will take about 7 g's
-Nate
#38
Nate, you already make right close to 400whp and are running 11.78. How do you expect to run 11.1 with the same power? I'm confused.
118mph traps = 390-400whp Dynojet
I think you've gone a little crazy in your expectations.
man i seriously can't wait for good cams to come out for the IX and see what the IX is capable of achieving on pump gas and stock turbo...
#40
Hey man, although at times I agree that I might be going crazy I am not in this particuliar situation. I had to sell my VIII because I had orders to Afghanistan, but they were canceled recently and I was left without a car. I called around and found that people were asking way too much for their used EVO's, or at least more than I am willing to pay. I ended up with South Coast Mistu(They are awesome BTW and gave me an awesome deal on my MR). With South Coast Mitsu I bought a 2006 EVO IX MR SE. All of the questions that I have been asking are in reference to the IX.
BTW, I really don't think that my last EVO was making 390-400whp. I believe that EVO's with the awesome launches they are capable of running allows for Drag times outside of the normal HP to Weight ranges.
I had never Dyno'd my last EVO so I will never know the true HP.
-Nate
#41
I agree with warrtalon on this one, I just don't see 400whp as enough to hit low 11s, but with absolutely awesome driving, anything is possible. Still a 50 or 75 shot of Nitrous would do the trick in combination with your mods.
#42
Actually with 400WHP, I could possibly believe a 11.3 or 11.4 E.T., but 11.1 would be tough.
Oops just noticed your talking about a MR, low 11s not going to happend with 400WHP.
#43
Originally Posted by fusionchicken
warr, i believe that was with his old Evo VIII, which he has since sold and now he has a IX to play with. all his questions refer to his newly bought IX. i think he talked about this in the original post.
Cams will be awesome!!!
-Nate
#44
I have always been one to try and beat expected results and if you look at the mods in my sig that my 2004 had you will see that I was pushing the envelope. The 2004 EVO had Stock Fuel Injectors/ Intercooler/ Turbo w/ 9.8 Hotside/ and much more the mods were it and BTW the 11.7 was made with meth and a mix of Pump and race gas, no more changes were made over the 12.0 run.
-Nate
#45
This is why I posted, to get all of the invaluable inputs.
Thanks,
-Nate
