could this be a reason for missing boost?
Old Oct 4, 2006 | 05:48 PM
chaz517's Avatar
Allrite so I have forge mbc on my evo but I can't get the boost level ti raise over 18psi and in sum gears it doesn't go that high, but anyways when you remove the stock vacuum line next to the boost control sensor thingy if that isn't plugged could that affect boost? Thanks in advance
Adding to that no matter how much I turn my boost controller up or down the boost level doesn't change why cud that be
Old Oct 4, 2006 | 05:56 PM
Rnm's Avatar
Rnm
What spring are you using? If you got the old batch of the Forge's, the soft spring was only good up to 19psi or so, thus you would have to use the stiff spring.
Old Oct 4, 2006 | 06:06 PM
chaz517's Avatar
I don't even know I bought it about a yr ago from pruven
Old Oct 4, 2006 | 06:23 PM
Ragnarok's Avatar
I would look up the "How-to" on the Forge MBC and make sure everything is hooked up according to the write up. If everything is correct, you are probably using the wrong spring.
I hope you get it figured out.
Old Oct 5, 2006 | 07:16 AM
chaz517's Avatar
allrite i guess thats gotta be it then, ill order a hallman and call it a day, thanks guys
Old Oct 5, 2006 | 07:31 AM
bigric09's Avatar
dont order the hallman... just get the heavy spring... that is what is wrong. if you can wait till monday, ill sell you my controller... pretty cheap, i jsut bought the aem truboost
Old Oct 5, 2006 | 10:07 AM
steevo's Avatar
yeah, just get the stiff spring, turn it all the way down, and adjust from there. contact Forge and they will send you the spring, and it's easy to replace.
ralliart610
Apr 15, 2016 09:45 AM
Mellon Racing
Feb 17, 2016 02:22 PM
RuskiEvo
Jan 10, 2016 04:11 PM
Ralliart909
Feb 24, 2015 01:44 AM
sgplancer
12
May 31, 2005 07:48 PM
Quick Reply: could this be a reason for missing boost?
