Need help removing front axle...
from the hub... I tried using a gear puller and also tried tapping it out with a block of wood and a hammer, no luck. Any other ideas? TIA
you need to screw a i think its a m8x1.25 bolt into it then attatch the slide hammer to the bolt and there ya go check out the faq on evomoto for clutch install REAL easy
I have always got it out with a large flat head screwdriver.
well pull the carter pin out from the middle of the half shaft then there is a BIG nut on the end un screw that and then you can unhook the stablizer bar if you want dont have to and just pull hard lol and should come out make sure you unhook the control arm be careful not to bust the ball joint did that help
If you're trying to get the shaft off the hub, you'll need to take the castle nut of the lower ball joint and pop the ball joint out. Once the balljoint if off, you should be able to move the hub far enough to push the axle through. It's been a while since I did this so I may have missed a step or two. Just be carefull not to damage the ball joint rubber boot.
Oh miss read I figured he knew he had to take the cotter pin and castle nut off. Then you either do as above stated or take the nut off the tie rod end pop that out and undo the 2 through bolts on the shock. The whole hub assembly will then swing out of your way. Now you can use your big screwdriver or small pry bar to pop it out
Fomer Vendor
If you think it seized, spray some PB buster in it or something. But you do need to take apart the tie rod's (you will probably break the bushings, I did) and the lower control arm to give it room to swing out of the way.
Other than that, get a big screw driver and a hammer and break it loose, than it should just slide out.
