Any of you guys using TORCO?
Old Oct 13, 2006 | 11:41 PM
mdog's Avatar
I'm learning more about the EVO platform and I notice alot of guys running C16/race gas either mixed or straight which of course eventually leads to lazy then dead 02 sensors. I know some people are able to access 104 unleaded, but does anyone mix their own? I use the TORCO race fuel concentrate and mix with 93 octane, and it's unleaded, which for me is the biggest thing. I use it when I'm wanting to be aggressive with my timing while spraying my stang, so I thought I'd see if anyone on here was using it with success.
5gal. 93+1can concentrate= 107 avg. octane
10gal.93+" " = 103-104 octane
20gal. 93+" "= 97-98 octane
I and a number of others have had good success with it and was I guess a bit surprised I didn't see more about it.
BTW- I don't sell this stuff or have any financial interest whatsoever.
Old Oct 14, 2006 | 12:21 PM
mdog's Avatar
Nobody? Hmmm......
Old Oct 14, 2006 | 06:53 PM
TurboIX's Avatar
I was using race fuel and mixing it with pump gas....But now I'm using torco.
All the Evos and Stis up here in Ak us Torco and love it..The car runs smooth as butter.
Old Oct 14, 2006 | 06:59 PM
Jasil's Avatar
I've used Torco in the past, many GN, Mustang, Vette guys use it. The problem is it enough for a security blanket or a couple of extra lbs. to run any serious boost you need Meth. or C16.
Old Oct 14, 2006 | 07:15 PM
4Gsixty3's Avatar
I run Xylene as octane booster.
1 Gal Xylene to a full tank of 93 will yield 94.7
2 Gal Xylene to a full tank of 93 will yield 96.4
3 Gal Xylene to a full tank of 93 will yield 98.1
my car was tuned in the summer, so normally i will add a gal of xylene whenever i get gas during the winter just to make sure i dont detonate with the winter cold air.
Old Oct 14, 2006 | 07:16 PM
4Gsixty3's Avatar
http://www.team.net/sol/tech/octane_b.html
Old Oct 14, 2006 | 07:24 PM
Sharkbite2000's Avatar
I just brought a case of that i was going to put it to the test on the dyno at pruven to see how it does. they said 1 can to 5gal 93oct. makes like 107octane.
Old Oct 14, 2006 | 07:32 PM
Rnm's Avatar
Rnm
I've been meaning to use it, but I'm still skeptical in only using one can of torco to my 10 gallons of 93 octane and knowing if it really works or not as I don't want to blow up my motor.
Old Oct 14, 2006 | 09:29 PM
mdog's Avatar
I don't blame your skepticism. I was as well even after seeing others use it with success. I called though and talked to tech. support to talk about the base of the product and how it bonded/mixed and they seemed to really know their crap. For me it's used as not only a safety net bus also a large aspect to increased performance as I can run a good bit more timing with it.
Do the Evo's not have knock sensors that pull timing if knock is sensed? Or if it gets to that point are you already hosed?
Old Oct 14, 2006 | 09:53 PM
kapolani's Avatar
I was curious about this additive too.
About your question. Yes the Evo as a knock sensor. When too many knock counts occur the ecu will pull timing. If the knocking occurs over a lengthy period it will switch to a different (low octane) timing map.
Old Oct 14, 2006 | 09:59 PM
Ralph's Avatar
I want to get some pretty soon and see how well it can improve my 91 octane..
Old Mar 9, 2007 | 05:52 PM
jaylene2004's Avatar
torco
im new here,and i have a question where do you buy the torco accelarator,i was down to simpatico at international rd.they are selling this around $23 per bottle there out of stock right now,im here in ak too.i drive the gray evo9 with gold kosie wheel. and how do you mixed this ,i just want to get at least 93 octane on our regular 90 octane gas. thanks a lot what color your evo9 .... see you later.
Old Mar 9, 2007 | 06:40 PM
Evo442's Avatar
http://www.norcalevo.net/index.php?o...2&topic=3016.0
see what you guys think
Old Mar 9, 2007 | 08:18 PM
kouzman's Avatar
i have used torco. pretty awsome product. i could spike 25-25psi without even 1 knockcount and the car would run much smoother...
Currently i am using Klotz Hitrate, a similar product which in a mic 9 gallons of 92 octane and 1 gallon of hitrate you get 103-105 octane leaded gas... Again allows for at least 2-3psi more boost without knocking....
Old Mar 9, 2007 | 08:25 PM
nos51's Avatar
i used torco c16 on my stock block k-series integra.made 584hp@25psi sc6176e.
big from me for torco
Quick Reply: Any of you guys using TORCO?
