is alky/Meth Kit recommended for daily dirvers?
Old Oct 14, 2006, 07:35 PM
FartMuffler's Avatar
Question is alky/Meth Kit recommended for daily dirvers?
couple of questions:
1) is an alky/meth kit reliable and recommended for everyday use and does it lower engine life?
2) is there a way to "switch" this option on/off?
3) besides a tune/flash... do u NEED any other mods, or can u run the alky/meth kit on a stock car?
4) wat kit is the overall best in terms of features and reliability?
Old Oct 14, 2006, 07:38 PM
blackevoguy's Avatar
well to answer number 3, you dont really use them on a "stock" car theres no need for it. Alky/meth is used so that higher boost levels can be run safely. Its pretty much an alternative to running race gas
Old Oct 14, 2006, 07:42 PM
yes i fully understand what the kit does But, u can use higher boost levels on STOCK turbo, correct? if this is so u can tune it so it takes advantage of this on stock or at certain rmp...
correct me if i'm wrong
Old Oct 14, 2006, 07:53 PM
reTro's Avatar
I want to know the answer to this too!!!
BTW, I was thinking about getting a Snow Performance kit.
Old Oct 14, 2006, 08:37 PM
Evo8zip's Avatar
well, its not gonna be stock cause you're gonna need a boost controller if you want to take advantage of having the alky in the first place.....and trying to run the boost you're capable of with it probably isnt advisable with the stock exhaust. not to mention itll be choked up and wont see as much gain to someone with exhaust + alky.....ooo and i almost forgot, youll run outta fuel on the stock pump too...so basically the kit would be dead weight on your car... just my .02
Old Oct 14, 2006, 08:44 PM
how do you run out of fule with the stock pump?
Old Oct 14, 2006, 08:48 PM
midwestmonster's Avatar
Don't forget head studs are recommended if you're going to run higher boost as well. Basically, there are plenty of mods to do before a meth kit that you'll be very happy with. Just my 2 cents.
Evo8zip's Avatar
i was hitting fuel cut at 21 psi on the stock pump. @21psi you dont need alky. at least i'd say you'd need exhaust, fuel pump, mbc and a tune to run alky
Old Oct 14, 2006, 08:53 PM
Evo8zip's Avatar
actually, i think the tune helped more than the pump...but i dont know how much you can run on the stocker...and more than stock levels for any extended time and youll kill your pump quickly im sure
Old Oct 14, 2006, 08:57 PM
h.funk's Avatar
I dont think people here no a lot about alki on a nissan..
Old Oct 14, 2006, 08:59 PM
Evo8zip's Avatar
haha i didnt even look at "drives", just assumed. and we all know what that means! if its for a turbo application, the concept of it isnt gonna change though
Old Oct 14, 2006, 09:16 PM
i deff meant on an EVO... i'm planning on picking one up soon so i wanna know all my options... alky seems a good way to go if its reliable
Old Oct 14, 2006, 09:18 PM
h.funk's Avatar
To be honest nothing is reliable on a Evo.
Old Oct 14, 2006, 09:27 PM
chaotichoax's Avatar
how do you know he does have an evo
I highly doubt he is asking about his nissian
I've been seeing your ignorant worthless posts on so many threads...save your breath man
Old Oct 14, 2006, 09:29 PM
again SHHH
4g63 find me something with a longer history
jesus help us
