high mount (third) brake light
Can anyone tell me what's the possibility of the third brake light NOT working? I just brought this Evo IX new two months ago and I did check the bulb and the fuse they all works fine.
Would it be something goes wrong with the Viper alarm system installed like a month ago?
Thanks
Thanks
It would have nothing to do with the alarm installation, as the only thing you would hook up to in relation to the brake lights is the brake output wire for a remote start. And if your other brake lights work then it has to be something with that light as they are simply tied in together. One thing you could do it take the power wire for the brake light and tap it in with the rear taillight brake wire and try to see if it works then....
If not then you know it is either the ground for that light or the bulb itself....
I found that the black cable tie body attachment thingy just forward of the drivers side boothinge had cut all the wires going to the number plate lights and the high stop lights.I added some more cable and joined them up then its all good.Hope this helps
blurr001
Oct 14, 2014 05:26 AM
