those with the SSL evos...have you encounter this problem?
hey all, i have an 05 tb evo with the ssl package. about a week ago i noticed that upon opening the sunroof, there is a loud noise coming from it. it still operates normally, i looked at the rails and found some dust and leaf particles. i took those out and tried to open/close it again. the noise is still there, however it still operates perfectly w/o the sound.
just wondering if any of you have come across this problem before and if so, what was the cause? thanks fellas.
mine started to do that then i opened it all the way and in nver closed... then it rained.... but on mine it was a loose bolt that finnaly worked its way out. Take it in or remove the headliner before it to late
Originally Posted by Yodobashi
This is a common problem. Apparently not all the bolts are torqued down to spec.
i dont think greasing the rails would help because when i was removing the dirt particles, my fingers got a lot of grease on it so it was plenty lubed already.
