installed MBC have questions
Old Oct 16, 2006 | 11:10 PM
fyr3's Avatar
is there anything negative not capping my WG solenoid lines would cause? i ask this because my boost isnt raising past 14 since i installed my MBC and this is after like 4 1/2 turns(hallman). Just in general how many turns does it take for you to set it to 20 psi?
*edit only performance mods i have is a TBE and a works air filter.*
Old Oct 16, 2006 | 11:12 PM
03redtype-s's Avatar
it will take some turns just keep opening slowly till it gets there. how do you have it hooked up do you haev it tapped into your bov line if so then you need to cap off the Factory boost solonoid inlet and out let and also the nipple on intake and turbo outlet pipe. when i had mine it took quite a few turns to get it there!!!
Old Oct 16, 2006 | 11:13 PM
tarmac4g63's Avatar
how do u have it hooked up? any pics?
Old Oct 16, 2006 | 11:16 PM
also make sure you factory boost solonoid is still hooked up even though you may not have any lines running to it
Old Oct 16, 2006 | 11:26 PM
fyr3's Avatar
sorry, forgot to explain. the directions said to hook it up straight to the compressor housing and wastegate. i capped off the bottom vacuum line going into the turbo inlet and will (but havent yet) cap off the wg solenoid soon. *edit* alright, since you had alot of turns too i guess im still far away lol. thanks for the answers!
Old Oct 16, 2006 | 11:37 PM
blackevoguy's Avatar
i thought i remember someone saying that theres a different spring that you can by for higher amounts of boost
the ones good for like 15 psi, and you need the other one to get the boost above that
im not real sure about this, but that could be the problem
Old Oct 16, 2006 | 11:38 PM
19psi's Avatar
dont be afraid to turn it.
Turn it one full turn and check you boost level on 3rd gear @ WOT.
BTW, you might want to get the car tuned to optimize your boost setting.
I would leave the boost very close to stock until a tune.
Old Oct 17, 2006 | 01:16 AM
fusionchicken's Avatar
sounds scary...so if it's overturned we could blow our engine while doing a 3rd gear WOT test? i hope there's a way to accurately turn it till the desired PSI...
Old Oct 17, 2006 | 04:38 AM
BretTheJet26's Avatar
my forge mbc took a really good amount of clicks before i got to 20psi. but when i had a hallman it was only like 1/4 turn
Old Oct 17, 2006 | 08:54 AM
19psi's Avatar
you can just keep turning @ one turn increments until you see the correct pressure.
Old Oct 17, 2006 | 09:36 AM
Evo8zip's Avatar
over 15psi, one turn on my hallman = a lot more boost.....is it the in cockpit version? if so thats easy to just turn a lil and check. if not it is a pita to turn a lil, go run, etc etc....and like stated....you should just go get tuned and that way you wont have to worry about it
evo8mr03
Mar 28, 2011 07:47 PM
bboy_RES
32
Jun 18, 2009 03:26 PM
evilevo22
41
Jan 13, 2007 11:55 PM
dbdude
Sep 25, 2005 12:33 PM
VIIImylunch
Aug 18, 2005 01:09 PM
Quick Reply: installed MBC have questions
