evoscan and the lc-1 how to. anyone???
Old Oct 19, 2006 | 01:12 PM
EvoDan2004's Avatar
how do i hook up the lc-1 to work with the evoscan. whats needed. i cant figure this out. lol.
Old Oct 19, 2006 | 01:26 PM
EvoDan2004's Avatar
bump
Old Oct 19, 2006 | 05:43 PM
SophieSleeps's Avatar
I'm about to buy a wideband and do the same.
I believe you will be hooking up the LC-1's cable to your laptop. Hook up the tactrix cable and open up evoscan.
There is an option to use a certain wideband. Select that and the com port that your wideband signal is coming in off of.
Old Oct 19, 2006 | 05:44 PM
Ralph's Avatar
Connect the LC1's serial cable to your PC.. directly it should work fine.
If you're forced to use a USB-Serial adapter.. get one from Radioshack that has the buldge in the cable + a Driver disk.. these seem to work fine.
Don't get a cheap adapter. It probably won't work.
Old Oct 19, 2006 | 05:54 PM
I have 6 or 7 USB-Serial adapters laying around.
None of them work. I think I literally bought every one that radio shack has.
Use this one. It is the only one I found that consistently works without error.
http://www.pfranc.com/usb/usb.shtml
Old Oct 19, 2006 | 06:36 PM
EvoDan2004's Avatar
ok thanks. hope i get the right one.
Old Oct 19, 2006 | 06:38 PM
EvoDan2004's Avatar
ok i clicked on find a dealer. a pic of the part came up. but how does the wideband plug to that.????
Old Oct 19, 2006 | 07:27 PM
EvoDan2004's Avatar
never mind. i looked in my innovate box and bam there was a cable for what i need it for. duh. i forgot it came with the kit.
Old Oct 19, 2006 | 07:58 PM
Ralph's Avatar
Now, if your laptop has a serial built in, you're golden. .
Old Jan 30, 2007 | 06:01 AM
recompile's Avatar
<resurrect thread>
From what I gather, does EvoScan allow you to view/log data simultaneously from Tactrix cable and also from LC-1 serial cable? So you could effectively log AFR and anything else from Tactrix cable together?
Is EvoScan the only program capable of doing this?
Old Jan 30, 2007 | 11:38 AM
grenade's Avatar
Originally Posted by ShamelessCookie
<resurrect thread>
1. from what I understand, yes you can log AFR, along with other's at the same time. You will need the plugins, that go into the laptop, but you know this.
Evo scan is not the only one, just one of the more common ones. HTH
Old Jan 30, 2007 | 11:41 AM
recompile's Avatar
OK, so I can connect serial cable from LC-1 and USB cable from Tactrix to laptop and use EvoScan to pull data from both sources to same log?
I'll probably buy EvoScan, unless someone can convince me it's not worth $25 ???
Old Jan 30, 2007 | 11:45 AM
grenade's Avatar
From what I've gathered, Yes. Actually, I hope so, becuase I purchased the same exact setup, hopeing to do this.
I think its worth it, but hey.. Some one wont. Money well spent if you ask me.
Old Jan 30, 2007 | 11:55 AM
bboypuertoroc's Avatar
Veteran: Army
Yes, it works. That's what I'm running.
Old Jan 30, 2007 | 12:06 PM
recompile's Avatar
Cool, thanks.
<offtopic> How's your Gruppe-S flywheel? How many miles on it? I spoke to another member who had it install and ended up blowing his motor... he's not sure if it's flywheel related. </offtopic>
desiromeo812
Apr 30, 2012 06:48 AM
EVOLex
Jul 3, 2008 10:31 PM
Evo8uk
Jun 4, 2008 09:38 PM
gosu.pianist
Feb 21, 2008 07:16 PM
Evol.ved
Feb 20, 2007 06:48 AM
Quick Reply: evoscan and the lc-1 how to. anyone???
