Quietest Evo IX exhaust
Originally Posted by bizzarro
well i got the hks hi power and its really quiet and looks really good,
In relation to stock, you can't get much closer than the StealthWORKS muffler. Even combined with the rest of our Exhale components, sound levels are nearly unchanged at idle/cruise and minimally louder when on the throttle.
Originally Posted by 555R
Fujitsubo RM01A
quiet
and make power
my dynos proved it
baslined at 297awhp with a DC downpipe and KN intake @ 20.3 stock psi
before the flash
quiet
and make power
my dynos proved it
before the flash
the quieter, the more restrictive, the less overall power!
plus, you mentioned you'd just get a cat-back? you'd not be looking at a noticable diffrence in power at all over stock! sounds to me like your just wanting the "look" of a aftermarket exhaust and not the"performance"? if you were truly looking for power gain's you'd get a tbe....
oh i forgot to tell you that
stock evo IXs average 240-250ish whp @ Turbotrix
mine dynoed stock psi and those bolt ons at 297 whp untuned
if it makes any difference its a 2006 evo9 MR
before the ECUTEK flash
the exhaust on the butt dyno did nothing for me
the downpipe from DC made a huge difference in the butt dyno
I went from 240 at the wheels on a MD to 272 with an MBC (21PSI peak), 2.5" downpipe, an e-bay resonated test pipe and the RM01A with a very conservative tune. I bleed boost ferociously up top due to the stock BOV still being in place (amongst other things) and I could probably make it an even 290hp/290ft.lbs. with the addition of a BOV and less boost drop.
Originally I had the HKS Hi-power which was just too noisy. I did notice a slight difference between the HKS and stock, no difference between the HKS and the Fujitsubo, other than sound, before tuning.
My Ganador racing Ti gd-792r is like stock at idle, a LITTLE louder than stock at cruising / light throttle, and perfect at wot if a little wooshy. It's not very rumbly or popy anywhere in it's operation and my guess would be solidly under 95db where it matters. It's 70mm before the single resonator opening to 80mm after and on to the muffler. The whole thing is one piece, only weighs 6kg, and exudes quality. Price, however, is an issue here.
