installing my MBC right now, broke a nipple i need to cap on the stock BC
can i leave it open, or should i glue it shut? any ideas...getting tuned tomorrow and need this **** to work right the first time.
not sure i used ams's b/c and i used there directions, only thing i had to cap off was the nipple under the intake and the one on the outlet of the turbo. mines hooked onto the wastegate and its t'd into the dv line
ok its all installed, perrin mbc..the instructions say the tighter it is, the lower the boost..well..tighted all the way i still hit over 25psi... and half way i get the same thing..
help please. the silver side is going toward the wastegate
man you made me have to look up the bloody thing
Loosen it all the way up it doesn't make sense via this picture to have it tightened down all the way. This thing is basically a spring and a ball inside more spring tension... more boost simple no?
Also if its still pegging the boost gauge it may be reversed. I don't think it is at this time..
Pocket Mo
I thought you were supposed to run a line directly from the turbo outlet to the MBC and from the wastegate to the MBC? I was under the impression the closer to the turbo the MBC is, the better it is.
We could ask our more experienced members here if there is a real or just percieved benefit since i don't know for sure
Pocket Mo
Originally Posted by RoadSpike
Well where do you want it to activate? At the boost level of the turbo housing or the manifold. Both are just preference imho.
Hmmm I see. I was just thinking with the turbine outlet, nothing else to disrupt the boost reading.
Personally i'd do whats easier and that would mean the turbo housing nipple.
