additional hp and torque?
right now have an ecu flash and mbc (went from WHP218 stock hp to WHP253 with tune and mbc). going to be adding a 3 inch turboback with a re-tune using ecu flash. what kind of wheel hp and wheel torque gains would you guys expect with the addition of the 3 inch turbo back..probably going to use stock cat converter for now.. its an 08 evo 8 running 93 gas
It's not a TBE if you use the stock cat. That means you're just adding a downpipe and cat-back. The downpipe adds no power when still using the stock cat, so your gains will be equivalent to the addition of a cat-back, which is about 12-15whp. You could gain the same amount by leaving the stock cat-back and stock downpipe while installing a test pipe for $90.
PERRIN_Jeff
67
Jun 25, 2008 08:33 PM
AutoMotoSports
Automotosports - Illinois
Jun 19, 2008 12:32 PM
04AWDTURBOEVO
93
Feb 24, 2007 06:53 PM
RIPPMODS
Lancer Aftermarket Forced Induction Tech
169
Apr 4, 2004 09:09 PM
