bov seems stuck
Old Oct 24, 2006 | 08:11 PM
PurEvo's Avatar
bov seems stuck
My stock IX MR bov seems as if it's stuck open. Air doesn't sound the same as it use to. It seems like when I push the gas and let off, air rushes out immediately like it's stuck open. I took it apart, inspected it and it looks to be fine. Anybody have any idea's??? Help me...
Old Oct 24, 2006 | 08:17 PM
wj4's Avatar
wj4
do you have an intake in order to hear this air sound you talk about? if you have another local evo owner around you, see if he/she would be willing to let you borrow the bov to see if it is the culprit in this case.
Old Oct 24, 2006 | 11:45 PM
douggsx's Avatar
Mine sounds like that too. I think its normal.
Old Oct 25, 2006 | 04:30 AM
honda-guy's Avatar
if it's stock open, then you wouldn't have any boost.
Old Oct 25, 2006 | 04:41 AM
Talon's Avatar
w0rd
Old Oct 25, 2006 | 04:53 AM
boostinjuice's Avatar
^^^correct
Old Oct 25, 2006 | 05:01 AM
PurEvo's Avatar
it's not stuck wide open i mean. When I floor it, i build boost slow( car doesn't pull as hard as it should.) I'll see if i can hear anything else odd when i drive to work.
Old Oct 25, 2006 | 07:54 AM
honda-guy's Avatar
do you have to vac line from the intake manifold hooked up to the DV.
when you had the DV off, did you look to see if the valve close tight. did you try to blow in it to see if it was air tight.
Old Oct 25, 2006 | 07:19 PM
PurEvo's Avatar
I think I found it. A little hole opened up on the rubber hose that connects the DV to the upper IC pipe. I guess it happen when I had my car worked on to install a clutch. Everything is good now.
