Need For Blow Off Valve?
Old Nov 13, 2006 | 12:33 PM
  #31
Rutt's Avatar
I guess I will make my speech again. Diverter Valves(DV) and Blowoff valves(BOV) are all the same thing.... a BYPASS VALVE(BV)!
People automatically assume that a BOV is vented to atmosphere and that a DV is recirculated. Wouldn't it be easier to ask if the motor will be an OEM MAF setup or an aftermarket MAP (speed density) setup instead making an unsupported assumption?
MAF equipped motors require a sealed system because if air that has been metered by the MAF gets vented to atmosphere by a DV/BOV/BV the engine will receive a rich air/fuel mixture. Aftermarket BOV's will not harm the performance of a MAF equipped motor as long as it is recirculated like the OEM setup. Just stay away from that ultra lothargic HKS SQV/SSQV crap.
If needed I can explain the difference between MAF and MAP systems but I am sure that information can be found on this site by doing a search!
If you are buying a BOV for the sound then you are buying it for the wrong reason!!!
Old Nov 13, 2006 | 12:40 PM
  #32
sparky's Avatar
Can someone give me a quick reply whether the JDM MR DV can be crushed as the 1G valve can? Sorry for the OT.
Old Nov 13, 2006 | 12:49 PM
  #33
PessimiStick's Avatar
Originally Posted by battlecattle
No I am not asking a question I was informing people that VTA is not bad on ALL EVOS which was previously said. Just for the person that said that to correct their post to say that all cars with a MAF.
The point I was making (which you missed), is that anyone that *is* asking the question, isn't running Speed Density on a standalone. Therefore, the answer is completely valid in that context.
Old Nov 13, 2006 | 03:12 PM
  #34
Warrtalon's Avatar
Yes.
Old Nov 13, 2006 | 03:26 PM
  #35
evolve_'s Avatar
So say I have an 8 and stock boost with a mail-in flash, I get a spike of 21 sometimes 22 do I need to upgrade my stock bov?
Old Nov 13, 2006 | 03:27 PM
  #36
Jeff_Jeske's Avatar
I am running the JDM DV on my 2003 EVO. I upgraded only because in 2003 the DV was plastic and didn't like to hold 20+ psi. The JDM metal DV which is what comes on the 2006 EVOs holds boost just fine. Determine how much boost you want to run then do a boost leak check at that psi and see if your DV will hold the pressure or not. Mine holds 27psi just fine. No reason to upgrade at all.
Old Nov 13, 2006 | 04:41 PM
  #37
TTP Engineering's Avatar
It would be a good idea. If you had an IX, the answer would be no.
Old Nov 14, 2006 | 10:39 AM
  #38
gsrboi80's Avatar
ALL evos don't have MAF..PERIOD! I am not talking about DV. Don't lump everyone together.
They do unless you switched to a different setup PERIOD Also no dont vent on any MAF equipped car PERIOD
If your running speed density or a blowthru. Then DUH obviously you can vent it. Its not rocket science. EVOM
Old Nov 14, 2006 | 10:41 AM
  #39
gsrboi80's Avatar
You need to stop talking...or explain completely what you mean. Because what your saying is ALL EVOS lose power with a BOV which is false. Mine does just fine.
-Josh
Obviously your cool EVO isnt running a MAF sensor. DUH.
Old Nov 14, 2006 | 11:24 AM
  #40
I am running VTA with a MAF and 540whp stock turbo.
Old Nov 14, 2006 | 11:37 AM
  #41
Warrtalon's Avatar
But it's not daily driven and doesn't really make 540whp.
Old Nov 14, 2006 | 11:48 AM
  #42
gsrboi80's Avatar
Yea that dont count
Old Nov 14, 2006 | 12:00 PM
  #43
06blkevo9's Avatar
sorry for my stupid question now, i have a evo IX i just got like 2 weeks ago and i put in the hks uip with the hks ss bov, also have the hks carbon fiber exhaust catback....is that bad for my car?
Old Nov 14, 2006 | 12:05 PM
  #44
With 128mph traps on MY DAILY DRIVER.
http://www.speedworldmotorplex.com/calc.htm
You do the math.
Old Nov 14, 2006 | 12:26 PM
  #45
Warrtalon's Avatar
We've been through this 1000 times, Scott. That calculator is not accurate for an AWD car.
Last time at the track, I trapped 109.5 consistently, and on their scale, I was showing 3380lbs with driver. Using that calculator, it says I have 346whp. Guess what, I only dyno'd 299.6 on a Dynojet - nowhere near 346. If you go by my ET of 12.30, it says I'm making 359whp - oops, even further off from reality.
Although no one knows how you magically went from 123 to 127mph traps, and although we haven't seen you duplicate it, 127.xx mph still only equals to 480-490whp, not 540whp. And when did it become a daily driver? It sure wasn't in the past.
Yes, 06, you made a pretty big mistake purchasing all those HKS parts - it was just a waste of money. The UICP is not hurting the car, but it's not helping either - it was just an expensive use of your money that could have been used towards parts that make power. The HKS SSQV _is_ bad for the car and should be sold then replaced with your stock BOV, which NEVER should have been removed. The cat-back is fine, but again, you just paid a lot for the HKS name and aren't making much power. It's important to not get sucked into the ricer mentality of only purchasing things from HKS if you care about performance. If you don't care, then buy whatever you want.
