Need some help/ideas
I am having some problems and I'm out of ideas on what to try.
I just had a clutch installed, and after it was put back together, I am not hitting enough boost. I am tuned for almost 26 psi on meth and I'm only hitting about 12-13 psi. The weird thing is that it can be intermitant - I will occasionally hit full boost, usually when I first start out. I initially thought I had a boost leak...leak test showed a leak where my meth nozzle was inserted into my stock aluminum intake pipe, so a bung was welded in and the nozzle holder screwed into that - prefect, fixed that leak. I thought that would be the end of it, but when I picked it up and test drove it, still hitting 12-13, with an occasional 26. The weird thing is that once the car is warm, the only time I "seem" to hit full boost is if I am letting the clutch out while flooring it - but I can't even do that consistantly.
Do you think there could be an issue with the clutch install? I have the ACT XTSS with Streetlight flywheel. What other things might it be? I also thought maybe my boost controller went bad so I switched to the SBR MBC I had here, but I have it almost all the way tight and I can only consistantly hit about 18 - better than the other one, but still not making it all the way to 26.
Any ideas would be appreciated!!!
