potential big boost problem helppp
Old Oct 28, 2006, 02:04 PM
Bueller's Avatar
I actually bumped into someone the other day who had the same issue. He said he realized it was an install issue. Dont quote me.
Old Oct 28, 2006, 02:06 PM
Bueller's Avatar
Page 2 PWN3D!!! Simply amazing...ive PWN3D sooo many page 2s, 3s, and 4s lately...its amazing. I dont know how im doing it.
Old Oct 28, 2006, 02:11 PM
Warrtalon's Avatar
I still don't know what you're talking about. We already explained why the MBC only gave 18psi - it was the soft spring. So now what is your question? Other Evo owners do not randomly see 24psi on the stock boost system - that is a bad thing. We don't know what you do to fix it, because we don't know what the problem is yet.
Old Oct 28, 2006, 02:15 PM
chaz517's Avatar
Oh ok well I dunno what the problem is either no clue, in my boost line there are little jets that look like nitrous jets do all evos have these tiny jets near the end of them? I have no clue what to do or how this problem could even occur
Old Oct 28, 2006, 02:19 PM
Warrtalon's Avatar
Jets? Do you mean restrictor pills? Little brass ***** with holes in them?
Old Oct 28, 2006, 02:21 PM
chaz517's Avatar
Ya those lol sry kinda resembled nitrous jets, are those necessary ? Cuz I'm missing one on the turbo line on the part connecting to the stock solenoid, I have on right at the beginning of the turbo tho, cud this be the problem?
Old Oct 28, 2006, 02:24 PM
Bueller's Avatar
Im confused about these jets...what jets? Oh wait, i think you mean restrictor pills??
Old Oct 28, 2006, 02:27 PM
chaz517's Avatar
Old Oct 28, 2006, 02:48 PM
quit3frankly's Avatar
bump for an answer
Old Oct 28, 2006, 03:12 PM
Warrtalon's Avatar
Uh, yes, those are 100% required when running stock boost. What the hell are you doing to your Evo, man?
Old Oct 28, 2006, 04:08 PM
steevo's Avatar
You are having the same problem I had with my Forge. You have a older version and is spiking to 24psi even with the soft spring which should max at 19psi. It is erratic and can be resolved by cleaning the unit, and greasing the ball. Search the forums for cleaning Forge and you will find the method. Don't blame you for going hallman though, or the new Forge units.
Old Oct 28, 2006, 04:16 PM
chaz517's Avatar
where can I get one of those restrictors? I didn't think you needed them because when you put in a boost controller you replace the lines. Or do I only not need them if I'm using a boost controller. I hopr I didn't do too much damage
Old Oct 28, 2006, 04:27 PM
steevo's Avatar
replace the lines with a mbc with no restrictor pills in them. if you want to go back to stock, use your stock lines or get them with the restrictor pills at mitsubishiparts.net.
Old Oct 28, 2006, 04:59 PM
chaz517's Avatar
Damn I'm reallly dumb, thanks a lot every1 for being for the most part very informative and understanding, I just won't drive it till I get my hallman on monday
Old Oct 28, 2006, 05:47 PM
Evolved Monkey's Avatar
Honestly, if I were you I would just return the hallman and save $80. Its really easy to just change the spring. But if you insist on using the hallman then its kool too...we would just feel like we wasted our breath...haha
