potential big boost problem helppp
#31
Originally Posted by steevo
You are having the same problem I had with my Forge. You have a older version and is spiking to 24psi even with the soft spring which should max at 19psi. It is erratic and can be resolved by cleaning the unit, and greasing the ball. Search the forums for cleaning Forge and you will find the method. Don't blame you for going hallman though, or the new Forge units.
#33
Lol ya I guess since I already ordered the halman ill stick with that and they come with the 2 lines for the wastegate n turbo so everything shud be ok after this lol sry if I wasted ne 1s breath, sry never knew or heard of or had a clue those nozzles cud play sich a abig role in this
