Mitsubishi WRC Motor
Old Oct 29, 2006 | 11:15 AM
  #31
ak47po's Avatar
Originally Posted by hotrod2448
Brake master cylinders. Front, rear and, probably the handbrake.
Thanks now i know.
Old Oct 29, 2006 | 11:27 AM
  #32
kilgoja's Avatar
it says the top speed is 137mph...that's kinda wierd....our evos go faster than that ....doesn't make sense since the rally car engine has more power...am i missing something here?
Old Oct 29, 2006 | 11:33 AM
  #33
dsevo's Avatar
^ but I bet they out accelerate most of us, even in the dirt.
Old Oct 29, 2006 | 11:34 AM
  #34
ak47po's Avatar
Probably dont want to give the competition the real facts.
Old Oct 29, 2006 | 11:39 AM
  #35
hotrod2448's Avatar
Probably gearing. They only gear them to go as fast as they need to. I'm sure top speed varies (along with gearing) depending on the rally. The shorter they can gear the car the better it gets off the corner.
Old Oct 29, 2006 | 11:49 AM
  #36
spdracerut's Avatar
As mentioned is the gearing. There's not too many stages where they're going much faster than 110-120mph. And that's only on stages that have some sort of a straight.
Also, the turbo inlet restrictior supposedly limits WRC cars to ~300hp. I have seen stats of like 450 ft-lb tq though! That's some killer low and mid-range....
I just did a quick calc and the 34mm inlet restrictor should limit the motor to about 28.5 lbs/min of air (depending on weather conditions of course). So that 300hp seems about right....
Old Oct 29, 2006 | 12:06 PM
  #37
kilgoja's Avatar
yeah....that would be awesome to have a 100 more ft/lbs. of torque...0-60 would be like 3 seconds...
Old Oct 29, 2006 | 12:12 PM
  #38
beastlytalon's Avatar
Originally Posted by 2006MRevo
That is one of the first gen 4G63 engines. If you look at your 92 Talon, you will see that this set-up is the same as yours.
Its not an early 4g63 because the earlier ones like my talon have the belts on the opposite side. Thats why in our Evo's it is changed for better weight balance. The tranny is on the same side as early cars and our Evo's.
Old Oct 29, 2006 | 02:43 PM
  #39
evo400's Avatar
Registered User
The WRC car pic you see is the latest version of the WRC crarisma not the evolution . The engine is a 4g63 variant but has a unique mitsi turbo on board. it is clockwize rotation and has its inlet tot the left of the pic (1) the exit on the pic is indeed the exhaust system. The turbo is similiar to a TR30R garrett . We were very lucky to go around the headquaters before they finally shut there doors as a full works team . The engine use a 34mm air restrictor infront of the turbo inlet , they make around 4 bar of boost of the line with full anti lag or turbo assist as they call it . The trannys in the cars are worth over 200k us$ fully sequential with paddle shift with gear change of around 0.04ms . they are full magnesium casings and run fully active diffs . Expect a WRC car of this spec to make over 550ftlb torque and around 350hp flywheel .
The stock looking rally car is the current works group n car which runs a 32mm restrictor . this ia a showroom class and the cars are built @ ADR MOTORSPORT UK,
this is the garage that does all EVO400'S work in the UK . they have 6 of the final evo 7 WRC cars priced from $300,000 each some of which were driven by tommi himself !!!!
Regards
Dave
Old Oct 29, 2006 | 10:18 PM
  #40
Yogi_B's Avatar
Those pipes going to the exhaust manifold, yeah, mitsi have been using them snice Evo4 days.
On my evo6.
Old Oct 29, 2006 | 11:29 PM
  #41
Boosted GP's Avatar
thats for the EGR valve, its for emissions regulations, its not anti lag.
Mike
EvoKnievo
Dec 30, 2016 02:35 PM
Evo-X-FTW
Nov 26, 2013 07:38 PM
evovillen
Oct 10, 2013 12:56 PM
BEKevo
11
May 6, 2012 07:29 PM
JdmGraphiteMR
Apr 1, 2010 01:55 AM
Quick Reply: Mitsubishi WRC Motor
