Most Accurate Boost Gauge on the Market.
#31
The Defi comes with a monting kit,but you have to drill hole's or use adhesive strip's they provide.I used Autometer EVO Steering Column Gauge Pod 52mm.
http://www.lancershop.com/customer/p...&cat=22&page=1
#36
Originally Posted by mike127
What's wrong ith the factory one?
Mike
Mike
There is nothing wrong other than the fcat that it wouldn't read any valuable info above the 1.5 bar.
I personally recommend Defi BF imerial gauge on PSI reading but that is jut my opinion. I tried at least 10 different gauges on my 12 turbo cars I owned and I found that Defi is just a desirable instrument that not only reads boost /vacuum but also it would do multiple funtions.
Carlos
#41
Originally Posted by -=SPECTRE=-
Most accurate boost gauge on the market is a digital display that runs off of a MAP sensor, like the Zeitronix. Any analogue gauge will be less accurate.
#43
Originally Posted by boostedwrx
^ it only reads to 1.5 bar
