Anything Else Needed?
I have a IX and I just purchased an safc2, leaning towards the Zeitronix Wideband to use to tune and also for a boost gauge.
I know from some reading that I should also get a walbro and some injectors...
My mods for now are just TBE.
so anything else needed for tuning and what future stuff should I buy?
also what size injectors would be good?
heres what i would do as far as mods
TBE
MBC
Custom tune
walbro fuel pump
boost gauge
with the custom tune you shouldnt need the safc. That should get you pretty good numbers you might even look into the warrtalon/buschur package pretty good deal there and will come with what you need minus the fuel pump i believe
Matt
TBE
MBC
Custom tune
walbro fuel pump
boost gauge
Matt
Here's what I would recommend:
-tbe (which you already have)
-mbc (forge or hallman, both are great)
-licp
-custom tuned
Basically that's all you need to have a pretty quick evo for simple bolt ons. As for the wideband, It is nice but not needed unless you and i think you do intend to tune your evo yourself since you already bought a safc. Injectors are fine until you want to change turbo ( unless i'm wrong here). A walbro fuel pump is not necessary yet but i would recommend it. Good luck with your mod path...once you start...there's no tuning back.
-licp
-custom tuned
yah but I want to be able to adjust settings I.E. for race gas without having to bust out the laptop...
plus i got a smoking deal on the safc and thats what made me go that route.
what size injectors would be good with this setup?
so everyones suggesting the tune then eh? might sell the safc and go that route still not sure though...
and yes of course I was planning to go with the MBC, but how much improvement is there with the LICP? I did notice how bad it bottlenecked when I was puting the exhaust on...
Originally Posted by evo150
have you thought about getting the tactrix cable and download ecu flash? buy a e-flash from a tuner for your mods then fine tune using your wideband and some sort of logger.
also if you didnt read above, I was trying to avoid using a laptop. but if i must I will.
Originally Posted by Benny G
what company has this? and what is the best for saving different maps?
Most all tuners do e-flash. The tactrix and laptop are just a cheaper route if you already have the laptop. Still if you don't want to use the computer listen to everyone and sell the safc and get a tune/flash. You can save your maps on the hard drive and back them up on disk.
