aem gauge help
Originally Posted by bigric09
he said the truboost.... i bet its showing neg 14... as far as the lights go, they wont show until you are in boost ... so as you boost the lights will illuminate where they are suppose to... either way, go do some basic driving, get into boost a little and see if the number counts from 14 to 0 and then back up to something else, maybe 4 or 5 if you are driving conservatively
mjo
SRT-8
but the a/f still bounces around like crazy and goes into the red, and then sometimes when im just cruising it gives me a - - - reading instead of numbers
ok thanks man, and yea im pretty sure its vaccum now that ive been driving it around for a while. it stays at 18 and then when i start boosting goes to lower numbers then all the way up to 22, so im guessing its working well. but my bars arent lighting up around the numbers. any idea y that is?
Thats right. The first version doesn't have the -. The way you know if it's reading vaccum is there won't be any lights on the outside. If the lights on the outside are lit, it's reading boost.
my lights on the outside arent lighting at all like i said before. i think its reading the boost and maybe the lights on the outside are broken
Also, in the pictures it shows like a ring of lights but in reality it only lights 1 led at a time as it goes around. You could check the gauge range. Put the Full setting at 30.
how to:
Hold both buttons for 3 seconds and release, then it will say PRG
Hold both buttons again for 3 seconds and it will go to Units (PSI / BAR)
Then you can just press both buttons for a moment to flip through the settings until you see full -> use the right button to make this value 30, (this makes the gauge a 30psi gauge). Once your done doing that press both buttons together a few times till it says RUN
how to:
Raceghost
Jun 1, 2016 12:30 AM
